I’ve been using CUDA for the past couple of months on a 64 bit windows 7 installation along with Visual Studio 2008. Recently i shifted to a 32 bit windows 7 installation and also updated my graphics card, which earlier was a 8600GTX and now is a GTX465. I’ve installed the relevant driver and the CUDA 3.1 toolkit.
Somehow if i try and compile the same Visual studio projects I’d used earlier, I get the following error
1>------ Build started: Project: CUDAServicenew, Configuration: Debug Win32 ------
1>Performing Custom Build Step
1>CUDAHelloWorld.cu
1>Catastrophic error: cannot open source file “C:/Windows/TEMP/tmpxft_0000082c_00000000-6_CUDAHelloWorld.cpp1.ii”: not a regular file
1>1 catastrophic error detected in the compilation of “C:/Windows/TEMP/tmpxft_0000082c_00000000-6_CUDAHelloWorld.cpp1.ii”.
1>Compilation terminated.
1>Project : error PRJ0019: A tool returned an error code from “Performing Custom Build Step”
1>Build log was saved at “file://c:\wamp\www\server_root\GPU_stitcher_live\SiftGPU\CUDAServicenew\CUDAServicenew\Debug\BuildLog.htm”
1>CUDAServicenew - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I can’t understand why the cpp1.ii file is not being opened, what is it that I’m doing wrong here? Any help would be greatly appreciated.
Regards,
Slartibartfast
