As part of the CUDA ToolKit documentation for installing CUDA10.2
I am trying to install the kernel headers and I run into the following problem:
ubuntu@jetson4:~$ sudo apt-get install linux-headers-$(uname -r)
[sudo] password for ubuntu:
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package linux-headers-4.9.108-tegra
E: Couldn’t find any package by glob ‘linux-headers-4.9.108-tegra’
E: Couldn’t find any package by regex ‘linux-headers-4.9.108-tegra’
ubuntu@jetson4:~$ uname -r
you may find some information about headers in L4T Document
Jetpack 4.3 has /usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/ in place
Did not you get CUDA installed while you been flashing OS to Jetson?
Typically it is installed during the process managed by sdkmanager and there is no need to process it manually.
you are probably referring to the documentation for x86_64 which is not applicable to aarch64 Jetson device
On the Jetson3, the AGX to which I flashed Cuda using the SDK,
I am having a problem with a proprietary Makefile when I execute “make”, this is the output:
cuda-core-10-0 libavcodec-dev libavformat-dev libgtk2.0-dev libhdf5-dev libjpeg-turbo8-dev libswscale-dev
Do you have any idea why I cannot locate cuda-core-10-0?
Esterina
Hi Esterina, is your makefile explicitly checking that the cuda-core-10-0 package is installed? I don’t think Jetson has that exact package, perhaps it was renamed. Here are the CUDA packages listed with ‘dpkg --list’ on my AGX Xavier with JetPack 4.3:
ii cuda-command-line-tools-10-0 10.0.326-1 arm64 CUDA command-line tools
ii cuda-compiler-10-0 10.0.326-1 arm64 CUDA compiler
ii cuda-cublas-10-0 10.0.326-1 arm64 CUBLAS native runtime libraries
ii cuda-cublas-dev-10-0 10.0.326-1 arm64 CUBLAS native dev links, headers
ii cuda-cudart-10-0 10.0.326-1 arm64 CUDA Runtime native Libraries
ii cuda-cudart-dev-10-0 10.0.326-1 arm64 CUDA Runtime native dev links, headers
ii cuda-cufft-10-0 10.0.326-1 arm64 CUFFT native runtime libraries
ii cuda-cufft-dev-10-0 10.0.326-1 arm64 CUFFT native dev links, headers
ii cuda-cuobjdump-10-0 10.0.326-1 arm64 CUDA cuobjdump
ii cuda-cupti-10-0 10.0.326-1 arm64 CUDA profiling tools interface.
ii cuda-curand-10-0 10.0.326-1 arm64 CURAND native runtime libraries
ii cuda-curand-dev-10-0 10.0.326-1 arm64 CURAND native dev links, headers
ii cuda-cusolver-10-0 10.0.326-1 arm64 CUDA solver native runtime libraries
ii cuda-cusolver-dev-10-0 10.0.326-1 arm64 CUDA solver native dev links, headers
ii cuda-cusparse-10-0 10.0.326-1 arm64 CUSPARSE native runtime libraries
ii cuda-cusparse-dev-10-0 10.0.326-1 arm64 CUSPARSE native dev links, headers
ii cuda-documentation-10-0 10.0.326-1 arm64 CUDA documentation
ii cuda-driver-dev-10-0 10.0.326-1 arm64 CUDA Driver native dev stub library
ii cuda-gdb-10-0 10.0.326-1 arm64 CUDA-GDB
ii cuda-gpu-library-advisor-10-0 10.0.326-1 arm64 CUDA GPU Library Advisor.
ii cuda-libraries-dev-10-0 10.0.326-1 arm64 CUDA Libraries 10.0 development meta-package
ii cuda-license-10-0 10.0.326-1 arm64 CUDA licenses
ii cuda-memcheck-10-0 10.0.326-1 arm64 CUDA-MEMCHECK
ii cuda-misc-headers-10-0 10.0.326-1 arm64 CUDA miscellaneous headers
ii cuda-npp-10-0 10.0.326-1 arm64 NPP native runtime libraries
ii cuda-npp-dev-10-0 10.0.326-1 arm64 NPP native dev links, headers
ii cuda-nsight-compute-addon-l4t 10.0.326-1 all NVIDIA Nsight Compute Addon
ii cuda-nvcc-10-0 10.0.326-1 arm64 CUDA nvcc
ii cuda-nvdisasm-10-0 10.0.326-1 arm64 CUDA disassembler
ii cuda-nvgraph-10-0 10.0.326-1 arm64 NVGRAPH native runtime libraries
ii cuda-nvgraph-dev-10-0 10.0.326-1 arm64 NVGRAPH native dev links, headers
ii cuda-nvml-dev-10-0 10.0.326-1 arm64 NVML native dev links, headers
ii cuda-nvprof-10-0 10.0.326-1 arm64 CUDA Profiler tools
ii cuda-nvprune-10-0 10.0.326-1 arm64 CUDA nvprune
ii cuda-nvrtc-10-0 10.0.326-1 arm64 NVRTC native runtime libraries
ii cuda-nvrtc-dev-10-0 10.0.326-1 arm64 NVRTC native dev links, headers
ii cuda-nvtx-10-0 10.0.326-1 arm64 NVIDIA Tools Extension
ii cuda-repo-l4t-10-0-local-10.0 1.0-1 arm64 cuda repository configuration files
ii cuda-samples-10-0 10.0.326-1 arm64 CUDA example applications
ii cuda-toolkit-10-0 10.0.326-1 arm64 CUDA Toolkit 10.0 meta-package
ii cuda-tools-10-0 10.0.326-1 arm64 CUDA Tools meta-package
Also you might want to make sure that your ~/.bashrc file contains the following lines at the end:
export PATH=/usr/local/cuda-10.0/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64:$LD_LIBRARY_PATH
I I modified my cuda.mk to reference cuda-toolkit-10-0.
I now no longer see the cuda-core-10-0 as a missing package. Thanks for than.
I now see only
and when I run apt-get update the following results:
Ign:14 https://repo.download.nvidia.com/jetson/t194 r32 InRelease
Err:15 https://repo.download.nvidia.com/jetson/common r32 Release
Could not handshake: Error in the pull function. [IP: 192.168.1.1 3128]
Err:16 https://repo.download.nvidia.com/jetson/t194 r32 Release
THanks
Which JetPack do you install?
Based on the log in comment#1, you looks like you are using older JetPack version.
For our latest JetPack4.3, which use r32 release, the kernel version should be 4.9.140-tegra.
nvidia@xavier:~$ uname -a
Linux xavier 4.9.<b>140</b>-tegra #1 SMP PREEMPT Mon Dec 9 22:52:02 PST 2019 aarch64 aarch64 aarch64 GNU/Linux
