Trying to parse and decode H.264 content using the CUDA Video Decoder API fails.
Have tried it using the cudaDecodeD3D9 from CUDA Code Samples.
With a .mp4 source file containing H.264 content the call to cuvidCreateVideoSource fails with CUDA_ERROR_INVALID_SOURCE. With other source files cuvidCreateVideoSource succeds but decoding fails (display has been enabled). MPEG2 content decodes ok.
The .mp4 files play fine using Quicktime and VLC.
What H.264 formats/profiles/encapsulations does the CUDA Video Decoder API support? Can anybody point to H.264 content that actually decodes using the cudaDecodeD3D9 sample?
I’m running
CUDA TOOLKIT 2.3
CUDA SDK 2.3
GTX 285 driver version 6.14.11.9062
Windows XP
Hi! I’m having the same issue with the opengl decode example. I just downloaded the latest SDK to be sure I had all the proper updates. Did you have any luck?
I’m running
CUDA TOOLKIT 2.3
CUDA SDK 2.3
GTS 8800 as device 0
GT 9600 as device 1 (note, I updated the sdk to use this device since it supports cuda 1.1 unlike my older 8800 which is only cuda 1.0)
Just so you know, I’m having a similar issue with the opengl sdk example with .mp4/H.264. Do we even need to use the VideoSource class? I’d like to pump things to be decoded from a memory buffer instead.
I succeed to use the cudaDecodeD3D9 sample to decode h.264 bitstream.
you must use the raw h.264 bitstream, not the bitstream with encapsulations.
If you use the raw h.264 bitstream,but still failed.
Make sure the bitstream start with sps,not the other data.
I have been told to develop some software to decode H.264 from an IP/camera, has any of you some idea of how to even start this? i dont have any idea about image or video processing, i am looking at this example codes that you mention i they seem a bit complicated, could you make a resume on the steps to use this code and the main functions i have to look for? like…
1st - Create a VideoDecoder objet and initialize it…
2nd…
3rd…
2nd…
3rd…
