Just started using CUDA-A Data Science, what is the recommended way to install 3rd party packages and extensive personal lib into the environment when I am using Jumpyterlabs to update the environment. Is there a way to wheel in package dependencies during the build from the working directory.
Related topics
| Install PyCuda on Jetson NX | 4 | 9521 | July 23, 2021 | |
| Updating packages on Jetson TX2 via JetPack 3.0 | 4 | 2668 | July 6, 2017 | |
| It is impossible (for me) to install pycuda - pleeeeeeeease help | 7 | 10183 | August 29, 2022 | |
| JaCUDA | 0 | 1573 | May 5, 2009 | |
| Which nvidia packages are needed to run pytorch? | 4 | 1873 | July 5, 2023 | |
| CuPy or other parallel methods for GPU usage on TX2? | 1 | 781 | February 28, 2022 | |
| Setting up CUDA/TensorRT manually on Jetson AGX Xavier | 12 | 21232 | January 5, 2021 | |
| Install cuda package independently | 5 | 402 | June 3, 2024 | |
| Libraries never installed | 1 | 139 | November 8, 2024 | |
| CUDA/Jetpack | 6 | 2788 | February 5, 2020 |
