I have similar issue at JIT-compiled legacy CUDA8 code fails to run on RTX2080 (Ubuntu 16.04), but have different system environment.
I have an old s/w (code available), which was written for CUDA8 (and not compatible to work with CUDA9/10 without code changes). I had to change the GPU to RTX2080Ti. OS is Ubuntu 18.04.
Information of installed nvidia-driver is
NVRM version: NVIDIA UNIX x86_64 Kernel Module 440.64.00 Wed Feb 26 16:26:08 UTC 2020
GCC version: gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)
The code terminated with following warning message:
/home/sonic/Desktop/WVI/.env/local/lib/python2.7/site-packages/torch/cuda/init.py:95: UserWarning:
Found GPU0 GeForce RTX 2080 Ti which requires CUDA_VERSION >= 9000 for
optimal performance and fast startup time, but your PyTorch was compiled
with CUDA_VERSION 8000. Please install the correct PyTorch binary
using instructions from http://pytorch.org
warnings.warn(incorrect_binary_warn % (d, name, 9000, CUDA_VERSION))
Found GPU1 GeForce RTX 2080 Ti which requires CUDA_VERSION >= 9000 for
Is there anything I can do to make it running with CUDA 8.0?
Or my only option is to fix this code, to make it suitable for CUDA9?
