Lenovo T530, has Nvidia NVS 5400M and Intel HD graphics 4000, Win10 64 bit.
Use Geforce Experience to install driver 392.58.
CUDA 9.0 (cuda_9.0.176_win10_network.exe), cudnn 7.6.5.32 (cudnn-9.0-windows10-x64-v7.6.5.32.zip)
My paddlepaddle program complains no CUDA-capable device detected, when run check.
you may find some log in following.
My question is
is there any way for me to check cudnn?
paddle.fluid.install_check.run_check()
Running Verify Paddle Program …
2020-02-26 22:01:43,185-WARNING: You are using GPU version Paddle, But Your CUDA Device is not set properly
Error: cudaGetDeviceCount failed in paddle::platform::GetCUDADeviceCountImpl, error code : 38, Please see detail in CUDA Runtime API :: CUDA Toolkit Documentation no CUDA-capable device is detected at (D:\1.7.0\paddle\paddle\fluid\platform\gpu_info.cc:72)
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi
Wed Feb 26 22:34:21 2020
| NVIDIA-SMI 392.58 Driver Version: 392.58 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 NVS 5400M WDDM | 00000000:01:00.0 N/A | N/A |
| N/A 48C P0 N/A / N/A | 61MiB / 1024MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
C:\Program Files\NVIDIA Corporation\NVSMI>nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Wed Feb 26 22:35:01 2020
Driver Version : 392.58
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVS 5400M
Product Brand : GeForce
Display Mode : N/A
Display Active : N/A
Persistence Mode : N/A
Accounting Mode : N/A
Accounting Mode Buffer Size : N/A
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-8f8ab9b2-62a3-92ec-d8c9-e5275bb25861
Minor Number : N/A
VBIOS Version : 70.08.A8.03.02
MultiGPU Board : N/A
Board ID : N/A
GPU Part Number : N/A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x0DEF10DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x21F517AA
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Link Width
Max : N/A
Current : N/A
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : N/A
Tx Throughput : N/A
Rx Throughput : N/A
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons : N/A
FB Memory Usage
Total : 1024 MiB
Used : 54 MiB
Free : 970 MiB
BAR1 Memory Usage
Total : N/A
Used : N/A
Free : N/A
Compute Mode : Default
Utilization
Gpu : N/A
Memory : N/A
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : N/A
Average FPS : N/A
Average Latency : N/A
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 48 C
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Video : N/A
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Video : N/A
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : N/A
