I have problem with registering mmaped to userspace memory to CUDA. Framework reports cudaHostRegister(…, …, cudaHostRegisterIoMemory) is unsupported on Xavier, but in cuda-for-tegra-appnote written that cudaHostRegister routine is supported.
Detailed explanation:
I’m experimenting with GPU access to XTRX SDR PCIe board.
I want to register mmaped to userspace BAR0 to CUDA to be able to read from it inside CUDA kernel.
Driver xtrx.c:
static int xtrx_probe(struct pci_dev *pdev,
const struct pci_device_id *id){ //init device
err = pci_request_regions(pdev, DRV_NAME);
bar0_addr = pci_iomap(pdev, 0, 1 << 12);// corresponding virtual address in kernelspace is valid and usable
}static int xtrxfd_mmap(struct file *filp, struct vm_area_struct *vma){ //mmap handler
vma->vm_flags |= (VM_IO | VM_DONTEXPAND | VM_DONTDUMP);
vma->vm_page_prot = pgprot_noncached(vma->vm_page_prot);
pfn = pci_resource_start(xtrxdev->pdev, bar) >> PAGE_SHIFT;
if (io_remap_pfn_range(vma, vma->vm_start,
pfn,
vma->vm_end - vma->vm_start,
vma->vm_page_prot)
) return -EAGAIN;
OR (same result)
res = vm_iomap_memory(vma, pci_resource_start(xtrxdev->pdev, bar), vma->vm_end - vma->vm_start);
Test program:
int main(int argc, char** argv){
device = findCudaDevice(argc, (const char**)argv);
checkCudaErrors(cudaSetDeviceFlags(cudaDeviceMapHost));
unsigned int * a_UA;
unsigned int * a;
const int GP_PORT_RD_HWCFG = 26;
void* mem; unsigned int * vmem,*pmem;
char * ldev=“/dev/xtrx0”;
enum xtrxll_mmaps {
XTRXLL_MMAP_CONFREGS_OFF = 0,
XTRXLL_MMAP_CONFREGS_LEN = 4096,
int fd = open(ldev, O_RDWR); // open device
//Test cudaHostRegisterMapped flag -
a_UA = (unsigned int *) malloc(XTRXLL_MMAP_CONFREGS_LEN + MEMORY_ALIGNMENT);
a = (unsigned int *) ALIGN_UP(a_UA, MEMORY_ALIGNMENT);
checkCudaErrors(cudaHostRegister(a, XTRXLL_MMAP_CONFREGS_LEN, cudaHostRegisterMapped)); // OK. cudaHostRegisterMapped supported//Test cudaHostRegisterIoMemory
mem = mmap(0, XTRXLL_MMAP_CONFREGS_LEN, PROT_READ | PROT_WRITE,
MAP_PRIVATE, fd, XTRXLL_MMAP_CONFREGS_OFF);
//vmem = (unsigned int ) ALIGN_UP((unsigned int)mem, MEMORY_ALIGNMENT); // no impact on error
vmem = (unsigned int *) mem;
printf(“XTRX GP_PORT_RD_HWCFG: 0x%x\n”,vmem[GP_PORT_RD_HWCFG]); // OK Prints correct register value. CPU Virtual address in userspace mmapped successfulycheckCudaErrors(cudaHostRegister(vmem, XTRXLL_MMAP_CONFREGS_LEN, cudaHostRegisterIoMemory)); // FAIL Return cudaErrorNotSupported
Is cudaHostRegisterIoMemory flag supported on Xavier?
