cudaMallocHost is causing cufftExecC2C to fail?
Hey all,
I’m getting CUFFT failures when I’m trying to use cudaMallocHost, but it doesn’t fail when I use the new and delete operators to allocate memory. Here are the error messages being printed
cufft: ERROR: D:/Bld/rel/gpgpu/toolkit/r2.1/cufft/src/execute.cu, line 1070
cufft: ERROR: CUFFT_EXEC_FAILED
cufft: ERROR: D:/Bld/rel/gpgpu/toolkit/r2.1/cufft/src/execute.cu, line 316
cufft: ERROR: D:/Bld/rel/gpgpu/toolkit/r2.1/cufft/src/cufft.cu, line 151
cufftSafeCall() CUFFT error in file <myImageFFT.cu>, line 23.
Here is the main.cpp file I’m using. It’s really simple just to show this error
#include <iostream>
#include <cuda.h>
#include <vector_types.h>
#include "cutil_inline.h"
#define IMAGE_WIDTH  256
#define IMAGE_HEIGHT 256
using namespace std;
extern "C" void myImageFFT(cufftComplex* image, dim3 imageDim);
int main(int argc, char* argv[]) {
	cufftComplex* image = NULL;
	dim3 imageDim(IMAGE_WIDTH, IMAGE_HEIGHT, 0);
	cutilSafeCall(cudaMallocHost((void**)&image, imageDim.x*imageDim.y*sizeof(cufftComplex)));
	myImageFFT(image, imageDim);
	cutilSafeCall(cudaFreeHost(image));
	cutilExit(argc, argv);
Finally, here is the myImageFFT.cu file. Also, very simple :)
#include <stdio.h>
#include <cufft.h>
#include <cutil_inline.h>
extern "C" void myImageFFT(cufftComplex* image, dim3 imageDim) {
	// use device with highest Gflops/s
	cudaSetDevice(cutGetMaxGflopsDeviceId());
	cufftComplex* d_Image;
	// allocate space for the image on the device
	cutilSafeCall(cudaMalloc((void**)&d_Image, imageDim.x*imageDim.y*sizeof(cufftComplex)));
	// copy the image from host memory to device memory
	cutilSafeCall(cudaMemcpy(d_Image, image, imageDim.x*imageDim.y*sizeof(cufftComplex), cudaMemcpyHostToDevice));
	// create the fft plan
	cufftHandle fftPlan;
	cufftSafeCall(cufftPlan2d(&fftPlan, imageDim.x, imageDim.y, CUFFT_C2C));
	// execute the forward fft
	cufftSafeCall(cufftExecC2C(fftPlan, d_Image, d_Image, CUFFT_FORWARD));
		// clean up memory
	cufftSafeCall(cufftDestroy(fftPlan));
	cutilSafeCall(cudaFree(d_Image));
	cudaThreadExit();
I am currently running Windows Vista SP1 32-bit, and I’m using a GeForce 9800 GTX. I’m also using the latest CUDA 2.1 drivers and toolkit. Are you not allowed to call CUDA functions from a .cpp file or something? Thanks for any advice!
-Will
Has anyone encountered this error before? It’s getting pretty annoying…
-Will
