cuDNN for TX1
Trying to download <cuDNN v4 Library for L4T (ARM64)> for TX1, but the link in the cuDNN download page after logon doesn’t work:
https://developer.nvidia.com/rdp/cudnn-download
Wondering where should I report this. Thanks a lot!
Hmm you appear correct - the downloading fails “no file”. We’ll look into it.
Also currently I think you might want to use “cuDNN v4 Library for L4T (ARMv7)” because of TX1 armhf root filesystem, which I have confirmed downloads ok: [url]https://developer.nvidia.com/rdp/assets/cudnn-70-linux-aarch64-v40[/url]
OK, it’s back up — thanks for reporting it.
Unfortunately this does not work with Torch… :(
Can someone fix the link?
Updated the arm64 link above.
For using Torch + cuDNN v4 on the default armhf sample root filesystem, you probably want to use the v4 bindings from [url]https://github.com/soumith/cudnn.torch/tree/R4[/url] and armhf cuDNN from here: [url]https://developer.nvidia.com/rdp/assets/cudnn-70-linux-armv7-v40[/url]
Hi.
Where is the cuDNN link for the ARM64 version for the TX1? Will the armhf version also work? I flashed the TX1 using Jetpack 3.1 (cuDNN 6.0). The deb packages are the /home/nvidia/cudnn directory. The packages have already been installed.
nvidia@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 4.4.38-jetsonbot-v0.2 #4 SMP PREEMPT Thu Sep 21 17:08:48 EDT 2017 aarch64 aarch64 aarch64 GNU/Linux
nvidia@tegra-ubuntu:~$ echo $LD_LIBRARY_PATH
/home/nvidia/torch/install/lib:/usr/local/cuda-8.0/lib64::/usr/local/cuda/lib64
I need to config the TX1 system for Torch extensions:
cp cudnn.h /usr/local/cuda-8.0/include
cp libcudnn* /usr/local/cuda-8.0/lib64
luarocks install cudnn
Update:
I went ahead and used the ARM7 cudnn files to perform the luarocks cudnn install. I ran into the following install message:
– CuDNN 5.1 not found at install-time. Please make sure it’s in LD_LIBRARY_PATH at runtime
The installation succeeded, but there could be an issue with using cudnn Release 4.
cuDNN’s libraries is located at ‘/usr/lib/aarch64-linux-gnu/’
For this link, https://developer.nvidia.com/rdp/assets/cudnn-70-linux-armv7-v40.
Is it CUDNN version 7.0? I got version 4.0 from its cudnn.h,
nvidia@tegra-ubuntu:/usr/local/cuda-8.0/include$ grep CUDNN_MA cudnn.h
#define CUDNN_MAJOR 4
I have a YOLO2 application running with CUDA8.0/CUDNN 6.0 on x86 Ubuntu 16.04 fine. When I ported it to Jetson TX1 with CUDA 8.0/above CUDNN 7.0 (or 4.0?), I got build error,
./src/convolutional_layer.c: In function ‘cudnn_convolutional_setup’:
./src/convolutional_layer.c:127:5: error: too many arguments to function ‘cudnnSetFilter4dDescriptor’
cudnnSetFilter4dDescriptor(l->dweightDesc, CUDNN_DATA_FLOAT, CUDNN_TENSOR_NCHW, l->n, l->c, l->size, l->size);
compilation terminated due to -Wfatal-errors.
Makefile:79: recipe for target ‘obj/convolutional_layer.o’ failed
This looks like library incompatible issue.
thanks,
Steve
From the error log, you are in the different version of cuDNN.
Please install Jetson with JetPack3.1.
JetPack 3.1 contains CUDA 8 and cuDNN 6. Align with your requirement.
Hi AastaLLL,
Thanks for the info. Actually I already have JetPack3.1/CUDA 8 installed. I couldn’t find where is my cuDNN so I just downloaded/installed https://developer.nvidia.com/rdp/assets/cudnn-70-linux-armv7-v40.
Is there a link for JetPack3.1’s cuDNN6? I would like to install it manually to avoid time consuming re-installation of everything.
thanks a lot!
Steve
We don’t release individual cuDNN package for Jetson anymore.
All the package should be installed via JetPack.
The link you shared is cuDNNv4 and for 32-bit L4T. Can’t be used on rel-28.1, which is already 64-bit.
cuDNN can be download and installed via JetPack directly.
Package is located at /usr/lib/aarch64-linux-gnu/
thanks for the clarification, AastaLLL,
Steve
Hi Experts
I have installed tensorflow (python3.5) from jetsonhack. When I import
tensorflow in python I get:
ImportError: libcudnn.so.6: cannot open shared object file: No such file or directory
Any hints?
In my folder usr/lib/aarch64-linux/gnu
I have a file libcidnn.so.5
(In addition I have folders cuda and cuda-8.)
Sojohans
