(no debugging symbols found)
terminate called after throwing an instance of ‘cudaError’
[New Thread 0x2af3fa21a590 (LWP 26105)]
Program received signal SIGABRT, Aborted.
0x0000003556830265 in raise () from /lib64/libc.so.6
(gdb) backtrace
#0 0x0000003556830265 in raise () from /lib64/libc.so.6
#1 0x0000003556831d10 in abort () from /lib64/libc.so.6
#2 0x000000355b4bec44 in __gnu_cxx::__verbose_terminate_handler ()
from /usr/lib64/libstdc++.so.6
#3 0x000000355b4bcdb6 in ?? () from /usr/lib64/libstdc++.so.6
#4 0x000000355b4bcde3 in std::terminate () from /usr/lib64/libstdc++.so.6
#5 0x000000355b4bceca in __cxa_throw () from /usr/lib64/libstdc++.so.6
#6 0x00002af3f8226667 in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#7 0x00002af3f8460680 in ?? () from /usr/local/cuda/lib64/libcudart.so.3
#8 0x00002af3f823d50e in cudaCreateChannelDesc () from /usr/local/cuda/lib64/libcudart.so.3
#9 0x00002af3f84f3733 in ?? () from /usr/local/cuda/lib64/libcufft.so.3
#10 0x00002af3f8511486 in ?? () from /usr/local/cuda/lib64/libcufft.so.3
#11 0x0000003556b4d798 in ?? () from /lib64/libc.so.6
#12 0x00002af3f82154e8 in ?? ()
#13 0x00002af3f81bd000 in ?? ()
#14 0x00002af3f847385b in ?? () from /usr/local/cuda/lib64/libcufft.so.3
#15 0x00002af3fa217990 in ?? ()
#16 0x000000355580d20b in call_init () from /lib64/ld-linux-x86-64.so.2
#17 0x000000355580d315 in _dl_init_internal () from /lib64/ld-linux-x86-64.so.2
#18 0x0000003555800aaa in _dl_start_user () from /lib64/ld-linux-x86-64.so.2
#19 0x0000000000000001 in ?? ()
#20 0x00007fff93ca6741 in ?? ()
#21 0x0000000000000000 in ?? ()
