we use GPIO04, GPIO05, GPIO20, GPIO21,but only GPIO04(GPIO_PA.02) can be controlled, GPIO21(GPIO3_PA.00), GPIO05(GPIO3_PA.01), GPIO20(GPIO3_PA.03) are used by null,
how could i fix this problem?
hardware design:
pinmux:
hardware design:
pinmux:
Hi 735038964,
It seems you are using the custom carrier board.
Do you want to use these 4 pins as Output?
How do you configure them in pinmux spreadsheet?
Have you checked if any driver may requested those pins?
1、we use jetpack 5.1.3
2、We are using pin B58 as input, which works fine. We use other pins as output, but they are occupied by (null), so we can not control them
3、pinmux changes:
4、there is no driver request those pins
these pin are used as p3737_vdd_3v3_sd、p3737_vdd_12v_pcie、p3737_vdd_dp,which are defined in tegra234-p3711-fixed-regulator.dtsi
Please share this dtsi for further check.
Have you tried to remove them from here?
# cat /sys/kernel/debug/gpio |grep PA.0
gpio-348 (PA.00 |fixed-regulators:reg) out lo
gpio-349 (PA.01 |fixed-regulators:reg) out hi ACTIVE LOW
gpio-350 (PA.02 )
gpio-351 (PA.03 |fixed-regulators:reg) out hi
gpio-352 (PA.04 )
gpio-353 (PA.05 )
gpio-354 (PA.06 )
gpio-355 (PA.07 )
I’ve just checked on the devkit, it seems default occupied by fixed-regulators, please try to remove them from regulator@110, regulator@111, regulator@114
