Hi~
I have designed a carrier board for our customer,but my carrier board use USB type A instead of type C.
when AGX Xavier SoM turns on FORCE RECOVERY mode, can USB work?
Can the device be listed on my pc
Hi~
When device is in recovery mode, only the device mode on the flash port will work. This is mentioned in the product design guide document.
To USB 3.1 Type -A port on my custom board these lines are connected,
1. USB0_DN and USB0_DP for USB 2.0 support
2. UPHY_TX1 and UPHY_RX1 for USB 3.0 support
I have seen some issue about USB, when using USB type A directly, you need to modify CFG and DTB.
I’m worried that in recovery mode, my USB type A can’t be recognized, so I can’t flash the new AGX Xavier SoM I bought.
The recovery mode only recognizes the usb device mode and it is triggered by hardware. Type A does not support device mode so it was not working by default.
Hi, please refer to the Figure 7-3. USB 3.1 USB Micro AB Connection Example and 15.1 USB Recovery Mode in OEM DG. Only USB0 and UPHY1 are available to recovery mode.
