I’m connecting to host via USB type C, power on the dev kit by pressing the ‘middle’ button then the ‘power’ button and release both. when trying to flash got the message that the board not in ‘recovery’ mode, using ‘lsusb’ command don’t see the board.
What I’m missing?
Are you using a VM? These will typically fail to pass through USB correctly. Otherwise, any time the recovery button is held down at the moment of either power up or power reset (and then let go of the recovery button), the AGX should be in recovery mode.
