Disclaimer: This response was generated as a potential AI-assisted troubleshooting guide. Steps should be tested and validated carefully in your development environment.
Customizing the UEFI Boot Splash Screen on JetPack 6.2.1 (L4T R36.4.7)
On JetPack 6, NVIDIA utilizes EDK2 UEFI for early boot graphics instead of the legacy CBoot pipeline. Replacing the early boot logo requires updating the asset bitmaps inside the UEFI source tree, compiling the binary, and flashing the updated A_cpu-bootloader partition.
1. Set Up the UEFI Source Environment (Host Machine)
On your Linux host machine where your Linux_for_Tegra BSP directory is located, initialize edkrepo and clone the NVIDIA EDK2 tree:
Install edkrepo tool
sudo apt-get update && sudo apt-get install -y python3-pip git
pip3 install edkrepo
Add NVIDIA manifest repository and clone r36.4 source
edkrepo manifest-repos add nvidia
edkrepo clone nvidia-uefi NVIDIA-Jetson r36.4.0
2. Replace Boot Logo Bitmaps
Navigate to the Asset directory inside the cloned repository and replace the default NVIDIA splash screen bitmaps with your custom logo images (maintaining the BMP format and original dimensions/filenames):
cd nvidia-uefi/edk2-nvidia/Silicon/NVIDIA/Assets/
# Replace the bitmap assets with your custom images:
Note: If you change file names or add new resolution assets, remember to register them inside nvidia-uefi/edk2-nvidia/Platform/NVIDIA/NVIDIA.fvmain.fdf.
3. Build the Updated UEFI Binary
Build the new uefi_jetson.bin target binary:
cd ~/nvidia-uefi
edkrepo sync
python3 edk2-nvidia/Platform/NVIDIA/Jetson/build.py
4. Flash Partition to Jetson Orin Nano
Copy the freshly compiled binary to your L4T bootloader directory and flash the CPU bootloader partition without reflashing the entire OS:
# Copy binary to your L4T BSP directory
cp images/uefi_jetson.bin <path-to-your>/Linux_for_Tegra/bootloader/uefi_jetson.bin
# Put Jetson Orin Nano into Recovery Mode, then run:
cd <path-to-your>/Linux_for_Tegra/
sudo ./flash.sh -k A_cpu-bootloader jetson-orin-nano-devkit internal
Optional: Replacing Ubuntu / GNOME Desktop Splash Logo
If you also want to replace the desktop login wallpaper or avatar displayed after UEFI hands control over to the OS kernel:
On the Jetson Orin Nano target board:
sudo cp /path/to/your_custom_logo.png /usr/share/backgrounds/NVIDIA_Login_Logo.png
sudo cp /path/to/your_custom_logo.png /usr/share/backgrounds/jetson_logo.png
