Custom driver handler set_test_pattern() not called after power_off()
I have an an IMX492 camera working on an Orin devkit with the latest Jetpack 5.1.2.
I need to control the test pattern for that sensor and have added a parameter “test_pattern” with the associated command TEGRA_CAMERA_CID_TEST_PATTERN to the kernel+driver.
I run “v4l2-ctl --set-ctrl test_pattern=11 -d 0” and can verify the sensor outputs the expected pattern.
The second time I run “v4l2-ctl --set-ctrl test_pattern=10 -d 0”, the test pattern doesn’t change and debug prints in the driver indicate that the handler “set_test_pattern” is not called the second time.
Looking at the output of dmesg, I indeed see only 1 call to set_test_pattern(), and a call to power_off() inbetween the 2 calls I made:
[  140.247870] imx492 30-001a: imx492_set_test_pattern: select test pattern 11   ## v4l2 command detected, handler called ==> OK
[  140.516140] imx492 30-001a: imx492_set_mode 880: HMAX=2193 => 1202
[  140.520336] imx492 30-001a: imx492_set_mode: mode 0, 8432x5648
[  140.520341] imx492 30-001a: imx492_set_mode: selecting test pattern 11
[  141.330743] imx492 30-001a: imx492_power_off: line 667  ## <== power_off causing issue?
## second call to v4l2-ctl, set_test_pattern() not called here
[  148.885530] imx492 30-001a: imx492_set_mode: mode 0, 8432x5648
[  148.885535] imx492 30-001a: imx492_set_mode: selecting test pattern 11  ## using stale value
[  149.779789] imx492 30-001a: imx492_power_off: line 667
So my question is: could it be that power_off() is causing the issue by preventing the call to set_test_pattern() in the driver?
If so, how can I make sure that set_test_pattern is called in all cases?
Thanks,
Alain
hello alain.gautherot,
did you implement this correctly? please check $ v4l2-ctl --all for all available camera controls.
I believe so:
$ v4l2-ctl --all
Driver Info:
	Driver name      : tegra-video
	Card type        : vi-output, imx492 30-001a
	Bus info         : platform:tegra-capture-vi:0
	Driver version   : 5.10.120
	Capabilities     : 0x84200001
		Video Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Media Driver Info:
	Driver name      : tegra-camrtc-ca
	Model            : NVIDIA Tegra Video Input Device
	Serial           :
	Bus info         :
	Media version    : 5.10.120
	Hardware revision: 0x00000003 (3)
Interface Info:
	Type             : V4L Video
Entity Info:
	Name             : vi-output, imx492 30-001a
	Function         : V4L2 I/O
	Pad 0x01000010   : 0: Sink
	  Link 0x02000015: from remote pad 0x1000003 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
	Width/Height      : 8432/5648
	Pixel Format      : 'RG12' (12-bit Bayer RGRG/GBGB)
	Field             : None
	Bytes per Line    : 16864
	Size Image        : 95247872
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Full Range)
	Flags             :
Selection Video Capture: crop, Left 0, Top 0, Width 8432, Height 5648, Flags:
Selection Video Output: crop, Left 0, Top 0, Width 8432, Height 5648, Flags:
Camera Controls
                     group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                     hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
				0: 0 (0x0)
				1: 1 (0x1)
                    sensor_mode 0x009a2008 (int64)  : min=0 max=12 step=1 default=0 value=0 flags=slider
                           gain 0x009a2009 (int64)  : min=1000000 max=16000000 step=1 default=1000000 value=1000000 flags=slider
                       exposure 0x009a200a (int64)  : min=21 max=500000 step=1 default=30000 value=21 flags=slider
                     frame_rate 0x009a200b (int64)  : min=2000000 max=10000000 step=1 default=10000000 value=2000000 flags=slider
                    black_level 0x009a2011 (int)    : min=0 max=2147483647 step=1 default=0 value=0
                   test_pattern 0x009a2012 (int)    : min=0 max=2147483647 step=1 default=0 value=0
           sensor_configuration 0x009a2032 (u32)    : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
         sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
      sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
                    bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
				0: 0 (0x0)
				1: 1 (0x1)
                override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
				0: 0 (0x0)
				1: 1 (0x1)
                   height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                     size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
				0: 1 (0x1)
				1: 65536 (0x10000)
				2: 131072 (0x20000)
               write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
               low_latency_mode 0x009a206d (bool)   : default=0 value=0
               preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
                   sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=12 flags=read-only
please help me to understand this control property,
for example, is it something like a mode setting for writing different sensor mode registers? what’s the expected sensor behavior?
The idea is to configure the sensor to produce a known output (test pattern).
set_mode() still exists to select a resolution and bit depth, but there are a couple of extra registers to enable the test pattern generation and select which test pattern (black, white, grey, vertical stripes, horizontal stripes).
Setting the test pattern in realtime using v4l2-ctl and gstreamer works fine:
But if I rely only on v4l2-ctl to select the test pattern (off/vertical or horizontal stripes) and capture frames, it doesn’t work: I always get the test pattern that was first set.
Subsequent calls will not change the test pattern.
I think the call to power_off() that I see in “dmesg” output after the first call to “v4l2-ctl --set-ctrl test_pattern=XXX” is causing the problem.
Subsequent calls to “v4l2-ctl --set-ctrl test_pattern=XXX” doesn’t generate any log in dmesg, so driver is likely not called.
I’m wondering why that would be.
please refer to below code flow, and it looks like it treat test_pattern=10 as init settings to configure the stream.
you may refer to the code snippet as following.
for example,
$public_sources/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/tegracam_v4l2.c
static int v4l2sd_stream(struct v4l2_subdev *sd, int enable)
                err = sensor_ops->set_mode(tc_dev);
                /* update control ranges based on mode settings*/
                err = tegracam_init_ctrl_ranges_by_mode(
                        s_data->tegracam_ctrl_hdl, (u32) s_data->mode);
$public_sources/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/tegracam_ctrls.c
int tegracam_init_ctrl_ranges(struct tegracam_ctrl_handler *handler)
        /* Use mode 0 control ranges as default */
        if (s_data->sensor_props.num_modes > 0)
                err = tegracam_init_ctrl_ranges_by_mode(handler, 0);
hence,
please give it a try by adding your set_test_pattern CID controls into tegracam_init_ctrl_ranges_by_mode functions to update control properties.
thanks, I did that and ensured that values from the device tree are indeed applied.
Still, driver doesn’t seem to be called after the V4L framework calls power_off().
Note however that if I use my C++ wrapper around V4L2, the commands to select test_pattern are working as long as camera capture is started (sensor not turned off).
I guess it must be an issue specific to v4l2-ctl because controls can’t be set while streaming is enabled?
that init ctrl only called once while sensor streaming started.
there’re some CID controls able to called while streaming, such as TEGRA_CAMERA_CID_GROUP_HOLD.
