My custom plugin is based on ds-example. I am trying to use EGL-CUDA interoperability to apply my CUDA kernel to an image. Following hints in ds-eample source code I am using CUDA driver API to map data:
if (NvBufSurfaceMapEglImage (&ip_surf, 0) !=0 ) goto error;
CUgraphicsResource *pCudaResource;
CUeglFrame *pEglFrame;
if (cuGraphicsEGLRegisterImage(pCudaResource,
ip_surf.surfaceList[0].mappedAddr.eglImage,
CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE)
!= CUDA_SUCCESS) {
GST_ERROR("Could n't register EGL image.");
goto error;
if (cuGraphicsResourceGetMappedEglFrame(pEglFrame, *pCudaResource, 0, 0)
!= CUDA_SUCCESS) {
GST_ERROR("Could n't get cuda EGL frame.");
goto error;
I use cmake to build plugin:
cuda_add_library(gstdsmyplugin SHARED gstdsmyplugin.cpp)
target_include_directories(gstdsmyplugin PUBLIC
${OpenCV_INCLUDE_DIRS}
${GST_INCLUDE_DIRS}
${DEEPSTREAM_INCLUDE_DIRS}
${CUDA_INCLUDE_DIRS}
target_link_libraries(gstdsmyplugin
frameproc # a lib with my CUDA kernel
${OpenCV_LIBS}
${GST_LIBRARIES}
${DEEPSTREAM_LIBRARIES}
${CUDA_LIBRARIES}
When I run my GStreamer app with the custom plugin the problem appears:
(gst-plugin-scanner:20047): GStreamer-WARNING **: 12:22:54.192: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstdsmyplugin.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstdsmyplugin.so: undefined symbol: cuGraphicsEGLRegisterImage
My LD_LIBRARY_PATH contains CUDA libs directory:
user@dev-nano:~$ echo $LD_LIBRARY_PATH
/usr/local/cuda/lib64
What lib contains the cuGraphicsEGLRegisterImage function?
What am I doing wrong?
I will be grateful for any help :)
