Dsexample code
613     CUgraphicsResource *cu;
614     cuGraphicsEGLRegisterImage(cu, dsexample->inter_buf->surfaceList[0].mappedAddr.eglImage, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);//crash!!
616
617     /* Use interop APIs cuGraphicsEGLRegisterImage and
618      * cuGraphicsResourceGetMappedEglFrame to access the buffer in CUDA */
619
620     /* Destroy the EGLImage */
Above is gstdsexample.cpp of deepstream 5.0 gst-plugin example code. I just added those two lines as suggested by the comments below and included a header.
It crashes at 614 line.
How can I get a opencv matrix from gstdsexample.cpp code example?
• Hardware Platform (Jetson Nano )
• DeepStream Version .5.0
• JetPack Version (valid for Jetson only 4.4.1)
• TensorRT Version
Can you refer to the document first? Implementing a Custom GStreamer Plugin with OpenCV Integration Example — DeepStream documentation
I did. That document does not give enough info. I have a jetson.
Sorry for late response, the following code can work:
CUgraphicsResource cu;
cuGraphicsEGLRegisterImage(&cu, dsexample->inter_buf->surfaceList[0].mappedAddr.eglImage, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
cuGraphicsUnregisterResource (cu);
You can not use a null resource pointer with cuGraphicsEGLRegisterImage().
