orin nano dev kit borad r35.5.0
after flash system via usb & cmd:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml \
-p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit internal
system boot normal from nvme ssd. I need run my drvier, so recompile kernel(without code modify),and
sudo cp Image /boot/Image
confirm: /boot/extlinux.conf is that /boot/image
but after reboot, system boot failed.
bios: nvidia configuration boot:extlinux
I read the explanation here on how to confirm which one of the two I am now:
Custom kernel fails to boot - Jetson & Embedded Systems / Jetson AGX Xavier - NVIDIA Developer Forums
