**• Hardware Platform (Jetson / GPU) Tesla T4
**• DeepStream Version deepstream5.0.1
**• TensorRT Version 7.0
**• NVIDIA GPU Driver Version (valid for GPU only) 440.118.02(10.2)
I print some output inside the parsing function
parse function:
print output:
I found that the probability value output in outputCoverageBuffer is wrong, causing a wrong result .
PGIE config info:
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../engine/yolov5l_helmet.engine
labelfile-path=../label/helmet_labels.txt
batch-size=5
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=10
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV5_Helmet.txt
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#0=RGB, 1=BGR
model-color-format=0
custom-network-config=yolov3-tiny.cfg
model-file=yolov3-tiny.weights
process-mode=1
0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=2
gie-unique-id=1
network-type=0
#is-classifier=0
output-blob-names=prob
0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
output-tensor-meta=1
cluster-mode=2
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV5
custom-lib-path=../nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo_helmet.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
nms-iou-threshold=0.5
pre-cluster-threshold=0.4
PGIE labels.txt:
helmet
no_helmet
SGIE0 config info:
[secondary-gie0]
enable=1
gpu-id=0
model-engine-file=../engine/resnet50_secondary0_helmet.engine
labelfile-path=../label/helmet_secondary0_labels.txt
gie-unique-id=2
operate-on-gie-id=1
config-file=config_infer_secondary0_resnet50_Helmet.txt
operate-on-class-ids=0
batch-size=5
bbox-border-color0=0;0;1;1
[property]
gpu-id=0
net-scale-factor=1
offsets=103.939;116.779;123.68
#offsets=124;117;104
#net-scale-factor=0.0039215697906911373
#0=RGB, 1=BGR
#1:pgie 2:sgie
process-mode=2
network-mode=2
num-detected-classes=3
gie-unique-id=2
operate-on-gie-id=1
batch-size=1
#0: Detector,1: Classifier,2: Segmentation
network-type=1
input-object-min-width=64
input-object-min-height=64
output-blob-names=output1;output2
classifier-async-mode=1
classifier-threshold=0.5
secondary-reinfer-interval=0
#output-tensor-meta=1
cluster-mode=2
parse-classifier-func-name=NvDsInferClassiferParseCustomResnet50_SGIE0
custom-lib-path=/opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer_customparser/libnvds_infercustomparser.so
[class-attrs-all]
pre-cluster-threshold=0.5
eps=0.2
SGIE0 labels.txt:
belt_helmet;right_helmet;wrong_helmet
