I retrained secondary gie but classification result is not much better than it was in PC.
PC classification accuracy : 80%
jetson nano classification accuracy : 10%
Do you know reason?
Below is my config file
--------video_config----------
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=2
num-sources=1
#uri=rtsp://root:root@10.10.100.101:554/cam0_0
uri=file:/home/hana/config/Primary_Detector_Nano/test1.avi
#uri=file:/home/hana/config/Primary_Detector_Nano/bus/917.jpg
gpu-id=0
cudadec-memtype=0
#camera-width=1280
#camera-height=720
#camera-fps-n=30
#camera-fps-d=1
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=1
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=3
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=1
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
border-width=0
text-size=0
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=-1
Set muxer output width and height
width=544
height=304
nvbuf-memory-type=0
config-file property is mandatory for any gie section.
Other properqties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
model-engine-file=Primary_Detector_Nano/resnet18.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
config-file=config_infer_primary_nano(khy).txt
[secondary-gie0]
enable=1
model-engine-file=Primary_Detector_Nano/resnet10.engine
gpu-id=0
batch-size=1
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes(khy).txt
[tracker]
enable=0
tracker-width=128
tracker-height=128
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
gie-unique-id=2
[tests]
file-loop=1
---------secondary config-------------
[property]
gpu-id=0
net-scale-factor=1
#model-file=…/…/models/Secondary_VehicleTypes/resnet18.caffemodel
#proto-file=…/…/models/Secondary_VehicleTypes/resnet18.prototxt
int8-calib-file=Primary_Detector_Nano/cal.bin
#mean-file=Secondary_VehicleTypes/mean.ppm
labelfile-path=Primary_Detector_Nano/labels(sec).txt
batch-size=1
model-color-format=1
0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
is-classifier=1
#process-mode=2
#network-type=1
#interval=0
output-blob-names=predictions/Softmax
classifier-async-mode=0
classifier-threshold=0.51
input-object-min-width=64
input-object-min-height=64
operate-on-gie-id=1
