jetson
• DeepStream Version
6.1.1
• TensorRT Version
8.4
questions
Secondary GIE uses mobilenetv2, in which the softmax layer is not added during mobilenetv2 model training. When testing the tensorRT model in python, the inference result is correct, but the classification result of secondary GIE in the C++ version of the pipeline is wrong.Below is the image preprocessing before python inference tensorRT model。
mean = np.array([123.675, 116.28, 103.53])
std = np.array([58.395, 57.12, 57.375])
images = [cv2.resize(cv2.cvtColor(img, cv2.COLOR_BGR2RGB), (112, 112)) for img in images]
images = [(img - mean) / std for img in images]
images_array = np.array(images)
batch_data = images_array.transpose((0, 3, 1, 2))
Configuration parameters of secondary gie in pipeline
[property]
gpu-id=0
net-scale-factor=0.018
offsets=123.675;116.28;103.53
#onnx-file=../../models/vehicle_class/vehicle_type_cls.onnx
model-engine-file=../../models/vehicle_class/vehicle_type_cls.onnx_b4_gpu0_fp16.engine
mean-file=../../models/vehicle_class/cls.ppm
labelfile-path=../../models/vehicle_class/labels.txt
#force-implicit-batch-dim=1
#batch-size=1
model-color-format=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
is-classifier=1
process-mode=2
output-blob-names=output
classifier-async-mode=1
classifier-threshold=0.51
input-object-min-width=112
input-object-min-height=112
num-detected-classes=7
#infer-dims=3;112;112
network-input-order=0
#operate-on-gie-id=1
#operate-on-class-ids=2
classifier-type=vehicleCls
#scaling-filter=1
scaling-compute-hw=2
Is there something wrong with the configuration? Can anyone help me?
