Anybody know where is the reference manual for cut?? I don’t need for cuda because I have.
in the examples of cuda there are method: cut_exit, cut_check_error, cut_device_init…
thank you!
CUT (Cuda Toolkit) is not actively supported by nVidia - it’s merely a toolkit to make the SDK sample code simpler. The only documentation to CUT is its source code and the comments therein.
