As cuTENSOR’s documentation states that cutensorContraction needs ‘GPU-accessible memory’, I tried to use it with memory allocated by cudaMallocManaged (see code below). (I wanted to contract tensors in an out-of-core fashion.)
If I set d=64 in my code, each of the three tensors/arrays requires 64^4 * 8 / 1024^2 MiB = 128 MiB (all of them fit onto my GPU at once) and everything works as intended. If I set d=196 (each tensor now requires 11 GiB – a single tensor would fit onto my GPU, but not all of them at the same time) everything still works. However, if I set d=256 (32 GiB per tensor – a single tensor does not fit onto my GPU anymore), calling cutensorInitTensorDescriptor the first time fails with CUTENSOR_STATUS_NOT_SUPPORTED.
Does anybody have a clue what’s going on here? I am using CUDA 10.1 on a Titan V (12 GiB) with 192 GiB RAM.
#include <stdlib.h>
#include <stdio.h>
#include <cuda_runtime.h>
#include <cutensor.h>
#include <unordered_map>
#include <vector>
// Handle cuTENSOR errors
#define HANDLE_ERROR(x) { \
const auto err = x; \
if( x != CUTENSOR_STATUS_SUCCESS ) \
{ printf("Error: %s in line %d\n", cutensorGetErrorString(x), __LINE__); exit(-1); } \
int main(int argc, char** argv)
// Host element type definition
typedef float floatTypeA;
typedef float floatTypeB;
typedef float floatTypeC;
typedef float floatTypeCompute;
// CUDA types
cudaDataType_t typeA = CUDA_R_32F;
cudaDataType_t typeB = CUDA_R_32F;
cudaDataType_t typeC = CUDA_R_32F;
cutensorComputeType_t typeCompute = CUTENSOR_R_MIN_32F;
floatTypeCompute alpha = (floatTypeCompute)1.0f;
floatTypeCompute beta = (floatTypeCompute)0.0f;
printf("Include headers and define data types\n");
// Create vector of modes
std::vector<int> modeC{'m','u','n','v'};
std::vector<int> modeA{'m','h','k','n'};
std::vector<int> modeB{'u','k','v','h'};
int nmodeA = modeA.size();
int nmodeB = modeB.size();
int nmodeC = modeC.size();
// Extents
std::unordered_map<int, int64_t> extent;
int64_t d = 64;
extent['m'] = d;
extent['n'] = d;
extent['u'] = d;
extent['v'] = d;
extent['h'] = d;
extent['k'] = d;
// Create a vector of extents for each tensor
std::vector<int64_t> extentC;
for(auto mode : modeC)
extentC.push_back(extent[mode]);
std::vector<int64_t> extentA;
for(auto mode : modeA)
extentA.push_back(extent[mode]);
std::vector<int64_t> extentB;
for(auto mode : modeB)
extentB.push_back(extent[mode]);
printf("Define modes and extents\n");
// Number of elements of each tensor
size_t elementsA = 1;
elementsA *= extent[mode];
size_t elementsB = 1;
elementsB *= extent[mode];
size_t elementsC = 1;
elementsC *= extent[mode];
// Size in bytes
size_t sizeA = sizeof(floatTypeA) * elementsA;
size_t sizeB = sizeof(floatTypeB) * elementsB;
size_t sizeC = sizeof(floatTypeC) * elementsC;
// Allocate
floatTypeA * A;
floatTypeB * B;
floatTypeC * C;
cudaMallocManaged(&A, sizeA);
cudaMallocManaged(&B, sizeB);
cudaMallocManaged(&C, sizeC);
printf("num elements: %ld %ld %ld\n", elementsA, elementsB, elementsC);
// Initialize data on host
for(int64_t i = 0; i < elementsA; i++)
A[i] = (((float) rand())/RAND_MAX - 0.5)*100;
for(int64_t i = 0; i < elementsB; i++)
B[i] = (((float) rand())/RAND_MAX - 0.5)*100;
for(int64_t i = 0; i < elementsC; i++)
C[i] = (((float) rand())/RAND_MAX - 0.5)*100;
printf("Allocate, initialize and transfer tensors\n");
// Initialize cuTENSOR library
cutensorHandle_t handle;
HANDLE_ERROR( cutensorInit(&handle) );
// Create Tensor Descriptors
cutensorTensorDescriptor_t descA;
HANDLE_ERROR( cutensorInitTensorDescriptor( &handle,
&descA,
nmodeA,
extentA.data(),
NULL,/*stride*/
typeA, CUTENSOR_OP_IDENTITY ) );
cutensorTensorDescriptor_t descB;
&descB,
nmodeB,
extentB.data(),
NULL,/*stride*/
typeB, CUTENSOR_OP_IDENTITY ) );
cutensorTensorDescriptor_t descC;
&descC,
nmodeC,
extentC.data(),
NULL,/*stride*/
typeC, CUTENSOR_OP_IDENTITY ) );
printf("Initialize cuTENSOR and tensor descriptors\n");
//Retrieve the memory alignment for each tensor
uint32_t alignmentRequirementA;
HANDLE_ERROR( cutensorGetAlignmentRequirement( &handle,
A,
&descA,
&alignmentRequirementA) );
uint32_t alignmentRequirementB;
B,
&descB,
&alignmentRequirementB) );
uint32_t alignmentRequirementC;
C,
&descC,
&alignmentRequirementC) );
printf("Query best alignment requirement for our pointers\n");
// Create the Contraction Descriptor
cutensorContractionDescriptor_t desc;
HANDLE_ERROR( cutensorInitContractionDescriptor( &handle,
&desc,
&descA, modeA.data(), alignmentRequirementA,
&descB, modeB.data(), alignmentRequirementB,
&descC, modeC.data(), alignmentRequirementC,
typeCompute) );
printf("Initialize contraction descriptor\n");
// Set the algorithm to use
cutensorContractionFind_t find;
HANDLE_ERROR( cutensorInitContractionFind(
&handle, &find,
CUTENSOR_ALGO_DEFAULT) );
printf("Initialize settings to find algorithm\n");
// Query workspace
size_t worksize = 0;
HANDLE_ERROR( cutensorContractionGetWorkspace(&handle,
&desc,
&find,
CUTENSOR_WORKSPACE_RECOMMENDED, &worksize ) );
// Allocate workspace
void *work = nullptr;
if(worksize > 0)
if( cudaSuccess != cudaMalloc(&work, worksize) ) // This is optional!
work = nullptr;
worksize = 0;
printf("Query recommended workspace size and allocate it\n");
// Create Contraction Plan
cutensorContractionPlan_t plan;
HANDLE_ERROR( cutensorInitContractionPlan(&handle,
&plan,
&desc,
&find,
worksize) );
printf("Create plan for contraction\n");
cutensorStatus_t err;
// Execute the tensor contraction
err = cutensorContraction(&handle,
&plan,
(void*)&alpha, A,
B,
(void*)&beta, C,
C,
work, worksize, 0 /* stream */);
cudaDeviceSynchronize();
// Check for errors
if(err != CUTENSOR_STATUS_SUCCESS)
printf("ERROR: %s\n", cutensorGetErrorString(err));
printf("Execute contraction from plan\n");
if ( A ) cudaFree( A );
if ( B ) cudaFree( B );
if ( C ) cudaFree( C );
if ( work ) cudaFree( work );
printf("Successful completion\n");
return 0;
