I have old application written under CUDA 2.0 with VS2005 so I installed the same set and I’m trying to build it my OS is WINDOWS 7
here is my buildlog.htm content
Build Log Build started: Project: SPH, Configuration: Release|Win32
Command Lines Creating temporary file "d:\magisterka\_SOURCE\Release\BAT0000022003908.bat" with contents
@echo off
"C:\CUDA\bin\nvcc.exe" -arch=sm_10 -use_fast_math -ccbin "C:\Program Files\Microsoft Visual Studio 8\VC\bin" -c -I "C:\CUDA\include"; -I./ -o Release\System_cu.obj Source\CUDA\System.cu
if errorlevel 1 goto VCReportError
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from "CUDA Build Step: Kernel"
exit 1
:VCEnd
Creating command line "d:\magisterka\_SOURCE\Release\BAT0000022003908.bat"
Output Window CUDA Build Step: Kernel
System.cu
Source/CUDA/System.cu(1) : fatal error C1083: Cannot open include file: 'cutil.h': No such file or directory
Results Build log was saved at "file://d:\magisterka\_SOURCE\Release\BuildLog.htm"
SPH - 1 error(s), 0 warning(s)
I’ve tried to set additional lib and include paths to:
$(CUDA_LIB_PATH);“$(NVSDKCOMPUTE_ROOT)\C\Common\lib”;E:\download\tinyxml_build\lib
$(CUDA_INC_PATH);“$(NVSDKCOMPUTE_ROOT)\C\Common\inc”;E:\download\tinyxml_build\inc
or
$(CUDA_LIB_PATH);“$(CUDA_COMMON_LIB)”;E:\download\tinyxml_build\lib where CUDA_COMMON_LIB was system environment variable set to “C:\ProgramData\Nvidia Corporation\Nvidia GPU Computing SDK\C\common\lib”
$(CUDA_INC_PATH);“$(CUDA_COMMON_INC)”;E:\download\tinyxml_build\inc where CUDA_COMMON_INC was system environment variable set to “C:\ProgramData\Nvidia Corporation\Nvidia GPU Computing SDK\C\common\inc”
or
$(CUDA_LIB_PATH);“C:\ProgramData\Nvidia Corporation\Nvidia GPU Computing SDK\C\common\lib”;E:\download\tinyxml_build\lib
$(CUDA_INC_PATH);“C:\ProgramData\Nvidia Corporation\Nvidia GPU Computing SDK\C\common\inc”;E:\download\tinyxml_build\inc
I tried many combinations of including libs but none of them works for me, please help me I’m really desperate now after many days of trying to figure it out
