I have a user interface created with MFC, I call a CUDA function when clicking one button.
When I build the project, which is a dialog-based MFC application, I got the error:
fatal error C1083: Cannot open include file: ‘cutil.h’: No such file or directory
But previously I was able to build it without the user interface, just as a CUDA application, and the program ran perfectly. Why this header file cannot be opened now?
Another strange thing is, I have #include <cuda.h> and #include <cuda_runtime_api.h> before #include <cutil.h>. But I only got one error with ‘cutil.h’ …
Btw, I am creating projects with VS 2008, with CUDA_VS_Wizard_W32.2.0.exe installed.
I thought it might because I created an MFC application, not CUDA application, so I changed the environment as follows, but the compiler still can’t find “cutil.h”…
[codebox]Configuration Properties → C/C++ → General:
Additional Include Directories = $(CUDA_INC_PATH);â€C:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK\common\incâ€
Debug Information Format = Program Database (/Zi)
Configuration Properties → C/C++ → Code Generation:
Runtime Library = Multi-threaded Debug (/MTd)
Configuration Properties → Linker → General:
Enable incremental linking = No (/INCREMENTAL:NO)
Additional Library Directories = “C:\CUDA\libâ€;â€C:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK\common\libâ€
Configuration Properties → Linker → Input:
Additional Dependencies = cudart.lib cutil32D.lib
Configuration Properties → Linker → Optimization:
Enable COMDAT folding = Do Not Remove Redundant COMDATs (/OPT:NOICF)[/codebox]
Thanks,
Yuping
