I have a 4-card RTX 3060 system with driver version 580.82.09. Using the nvidia/cuda:13.0.1-cud decoder-devel-ubuntu22.04-1 base image, I created 4 separate containers mapping cards 0-3 into each container respectively. Cards 0, 1, and 2 all return the error cuvidGetDecoderCaps(&decodecaps) returned CUDA_ERROR_NO_DEVICE (code: 100), while only card 3 returns correct results from cuvidGetDecoderCaps(&decodecaps). However, when I map all 4 cards into a single container simultaneously, each card returns correct results. Using the same code, on another system with driver 535.274.02 using the nvidia/cuda:12.8.1-devel-ubuntu20.04 image, I created 4 containers using the same method, mapping the 4 cards into each container separately, and cuvidGetDecoderCaps(&decodecaps) returns correct results on all cards
System Information:
system: ubuntu:22.04
Nvidia card: four NVIDIA GeForce RTX 3060
Nvidia dirver : 580.82.09
Code project address and replication method: git@github.com:Yyong25/nvidia_decoder_test.git
Create 4 containers, map 4 cards each, only one card can output correctly
Related topics
| cuvidGetDecoderCaps(&ctx->caps8) failed | 1 | 761 | March 12, 2021 | |
| cuvidCreateDecoder returns CUDA_ERROR_NO_DEVICE | 1 | 1263 | January 26, 2017 | |
| cuvidCreateDecoder() get a "CUDA_ERROR_NO_DEVICE " return | 0 | 411 | May 29, 2019 | |
| Failed decoding pod: Error Type : m_api.cuvidGetDecoderCaps(&decodecaps) returned error 100 | 1 | 108 | January 31, 2026 | |
| Unable to get Decoding Capabilities by cuvidGetDecoderCaps | 0 | 910 | February 16, 2021 | |
| NV_ENC_ERR_UNSUPPORTED_DEVICE on Quadro RTX3000 mobile | 1 | 633 | May 28, 2021 | |
| cuvidGetDecoderCaps can`t found in libnvcuvid.so, cuda version is 375.20 | 1 | 2181 | October 9, 2018 | |
| cuvidCreateDecoder returns CUDA_ERROR_NO_DEVICE | 1 | 1599 | August 16, 2016 | |
| CUDA_ERROR_INVALID_DEVICE when trying to created decoder on P4000 on some drivers | 3 | 1373 | July 21, 2022 | |
| cuvidCreateDecoder() returns error CUDA_ERROR_NO_DEVICE | 13 | 3280 | October 27, 2017 |
