I have been using this exporter Photoshop_Plugins_x64_8.55.0109.1800 with PSD for sometime now, creating 3D video game assets. My copy of PSD is a legacy version, however, it does exactly what I require. The problem arises when an Alpha channel is added to the PSD image. Remove Alpha and exporter works. Interestingly I can edit previous files that successfully saved with an Alpha channel using this module from many months ago, and the exporter will save with Alpha channels. A new image won’t save. I used to get this error in the past if the selection tool was active on an image. I simply unselected the tool and the exporter worked fine. Unfortunately this is severely impacting my income stream.
Related topics
Topic | Replies | Views | Activity | |
Problem with Photoshop DDS plugin | 1 | 2169 | September 11, 2013 | |
New Nvidia Texture Tool Exporter doesn't save alpha channels | 30 | 9024 | October 12, 2021 | |
Files are not saved in adobe photoshop in dds format | 0 | 739 | January 9, 2023 | |
New Nvidia Texture Tool Exporter doesn't save alpha channels | 0 | 376 | March 26, 2020 | |
Doesn't give an option to export as DDS within Photoshop | 3 | 22838 | February 21, 2022 | |
.DDS not showing up in any save/export file type | 1 | 202 | November 28, 2024 | |
DDS Plugin Photoshop CS2 not working | 1 | 11155 | July 16, 2013 | |
Nvidia Texture Tools Exporter will not install in Photoshop CC 2020 | 22 | 11897 | March 26, 2024 | |
NVTT Plugin, Export not seeing alpha but standalone works fine | 0 | 376 | July 5, 2020 | |
First DDS loading in PhotoShop crashes | 9 | 4469 | January 19, 2023 |
