nvidia-bug-report.log.gz (267.9 KB)
Hello, I have been tried many solutions even in the forum. But none of them could help me. When i install nvidia-driver then nvidia-xconfig (will create file on etc/X11/xorg.conf then i restart. I will have only second monitor but
primary laptop monitor is turn into black with _ flashing. Can somebody help me ?
lshw -c video
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: TU106M [GeForce RTX 2060 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:173 memory:c5000000-c5ffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:4000(size=128) memory:c4000000-c407ffff
*-display
product: CometLake-H GT2 [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 05
width: 64 bits
clock: 33MHz
configuration: driver=i915 latency=0
resources: irq:143 memory:c3000000-c3ffffff memory:a0000000-afffffff ioport:5000(size=64) memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
lspci |grep VGA
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation TU106M [GeForce RTX 2060 Mobile] (rev a1)
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x48 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 6 associated providers: 0 name:modesetting
Provider 1: id: 0x291 cap: 0x2, Sink Output crtcs: 4 outputs: 3 associated providers: 0 name:NVIDIA-G0
xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 460.32.03
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/psaux”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
Identifier “Keyboard0”
Driver “kbd”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
i tried setprovider but error like this
xrandr --setprovideroutputsource modesetting NVIDIA-G0
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 35 (RRSetProviderOutputSource)
Value in failed request: 0x291
Serial number of failed request: 16
Current serial number in output stream: 17
