I’m using 3.2.4 32 bit and VS2012. I can link and execute my code using the none debug libs but when I try to use the debug versions I get a variety of link errors. The only one which doesn’t generate errors is: PhysX3DEBUG_x86.lib. For example if I use PhysX3CommonDebug_x86.lib I get this error:
1>PhysX3Extensions.lib(ExtExtensions.obj) : error LNK2019: unresolved external symbol “__declspec(dllimport) unsigned int __cdecl physx::Cm::addToStringTable(class physx::shdfnd::Array<char,class physx::shdfnd::ReflectionAllocator > &,char const *)” (_imp?addToStringTable@Cm@physx@@YAIAAV?$Array@DV?$ReflectionAllocator@D@shdfnd@physx@@@shdfnd@2@PBD@Z) referenced in function _PxDumpMetaData
I don’t see this error if I link the release version of the lib. PhysX3Extensions.lib as similar pproblems.
I’m trying to get the visual debugger to work and currently: NULL == g_Physics->getPvdConnectionManager()
returns null. I assume that’s because the libs are release and not debug?
