Debugging hints required
hello all,
I have run into a strange problem with my CUDA code for matrix multiplication.
Its an implementation where a block 64 1D threads computes 64x64 elements by using register tiling for one matrix and shared memory for the other.
The blocks compute correctly except for last row of last N-1 blocks when N is the number of blocks on x dim. The difference between two consecutive blocks is always same: 896.
If for example i try 256x256 dim then
rreddy78@jetson-nano:~/projects/test$ ./matrixMulTiled8
C[256 x 256]. grid config = (4,4) for block config = (64x1)
Difference between two is: 896
Error greater than tolerance at 255,64: 3712 - 255,127: 3712
Error greater than tolerance at 255,128: 2816 - 255,191: 2816
Error greater than tolerance at 255,192: 1920 - 255,255: 1920
if I use 512x512 then:
C[512 x 512]. grid config = (8,8) for block config = (64x1)
Error greater than tolerance at 511,64: 8320 - 511,127: 8320
Error greater than tolerance at 511,128: 7424 - 511,191: 7424
Error greater than tolerance at 511,448: 2944 - 511,511: 2944
How should we approach debugging for such a problem ? The same kernel code works for all other blocks and nothing is hard coded.
__global__ void matrixMultiplicationKernel(const float *__restrict__ A, const float *__restrict__ B, float *__restrict__ C, const int M_Size, const int W_Size, const int N_Size)
    // blockDim.y = 1 and threadIdx.y = 0
    const int ROW = (TILE_WIDTH * blockIdx.y) * blockDim.y + threadIdx.y; // Absolute C row index
    const int COL = blockIdx.x * blockDim.x + threadIdx.x;                // Absolute C column index
    __shared__ float Ads[TILE_WIDTH][TILE_WIDTH];
    register float BRT[TILE_WIDTH];          // B Register Tile
    register float tmpSum[TILE_WIDTH] = {0}; // tmpSum in registers
    for (int tileOffset = 0; tileOffset < W_Size; tileOffset += TILE_WIDTH)
        // Load the B Tile into registers and A Tile into shared memory
        //#pragma unroll
        for (int idx = 0; idx < TILE_WIDTH; idx++)
            BRT[idx] = B[((tileOffset + idx) * N_Size) + COL];
        //#pragma unroll
            Ads[idx][threadIdx.x] = A[((idx + ROW) * W_Size) + (tileOffset + COL)];
        __syncthreads();
            //#pragma unroll
            for (int idx2 = 0; idx2 < TILE_WIDTH; idx2++)
                tmpSum[idx] += Ads[idx][idx2] * BRT[idx2];
            __threadfence();
        __syncthreads();
        C[((ROW + idx) * N_Size) + COL] = tmpSum[idx];
void matrixMultiplication(const float *__restrict__ A, const float *__restrict__ B, float *__restrict__ C, const int M_Size, const int W_Size, const int N_Size)
    // declare the number of blocks per grid and the number of threads per block
    dim3 threadsPerBlock(TILE_WIDTH, 1);
    dim3 blocksPerGrid(1, 1);
    blocksPerGrid.x = (N_Size + (threadsPerBlock.x - 1)) / threadsPerBlock.x;
    blocksPerGrid.y = (M_Size + (TILE_WIDTH - 1)) / TILE_WIDTH;
    printf("C[%d x %d]. grid config = (%d,%d) for block config = (%dx%d)\n", M_Size, N_Size, blocksPerGrid.x, blocksPerGrid.y, threadsPerBlock.x, threadsPerBlock.y);
    matrixMultiplicationKernel<<<blocksPerGrid, threadsPerBlock>>>(A, B, C, M_Size, W_Size, N_Size);
    checkCuda(cudaDeviceSynchronize());
Even if I change from local arrays to shared memory (for variables tmpSum and BRT), the result in exactly the same.
Here’s the sequence I would follow:
  1. Populate your arrays with a data pattern that makes it easy to understand results. For this I used setting the A matrix to all 1.0 and setting the B matrix to 0 1 2 3 0 1 2 3 etc.
  2. Identify the smallest problem size that shows the problem. In my case it appeared to be 128x128 (2x2 blocks).
  3. Select a particular element that is showing an incorrect result. Identify the ROW and COL for that element. In my case one element that showed an issue was in the last matrix line, at element (ROW + idx) = 127 and COL = 97
  4. Using (ROW+idx) and COL determined in step 3, set some printf statements in your kernel which print out the sequence of values used to compute that item. You already have the necessary loops and whatnot, so this can basically be a 1-line addition to your kernel code.
This should get you a long way towards discovering the problem. When I did that, I discovered, to my surprise, that the Ads values that were used during the tempSum accumulation had some values that were not 1.0f (!). Tracking this down further eventually led me to this line of code:
I’ll stop there and leave it for you unless you want me to explain exactly the issue and solution.
Mentally I think of this approach as “grabbing the tiger by the tail and see where it leads you”. Identify an aspect of the result that you know is wrong. Successively work backwards through the calculations that led to that (wrong) element. You can do this with printf. You can do it similarly with a debugger and conditional breakpoints, but either way it will generally involve multiple “passes” as you work backwards until the root cause becomes evident.
Thank you!.
I will use this technique as cuda-gdb does not work for me…
Corrected the logical error in the line:
Ads[idx][threadIdx.x] = A[((idx + ROW) * W_Size) + (tileOffset + threadIdx.x)];
