Why my tiled matrix multiplication has no acceleration over the naive cuda version?
here is my tiled matrix multiplication version
include
include “…/tools/common.cuh”
using namespace std;
const int TILE_WIDTH = 16; // 必须加const
//extern shared float sharedA;
//extern shared float sharedB;
struct Matrix
int width;
int height;
float *elements;
// 获取矩阵A的(row, col)元素
device float getElement(Matrix *A, int row, int col)
return A->elements[row * A->width + col];
// 为矩阵A的(row, col)元素赋值
device void setElement(Matrix *A, int row, int col, float value)
A->elements[row * A->width + col] = value;
// 矩阵相乘kernel,2-D,每个线程计算一个元素
global void tiledMatMulKernel(Matrix *A, Matrix *B, Matrix *C)
// block内共享内存,矩阵维度必须是常量,否则编译报错
shared float sharedA[TILE_WIDTH][TILE_WIDTH];
shared float sharedB[TILE_WIDTH][TILE_WIDTH];
float Cvalue = 0.0;
int tx = threadIdx.x;
int ty = threadIdx.y;
int bx = blockIdx.x;
int by = blockIdx.y;
int row = ty + by * blockDim.y; //线程计算的元素所在的行,(row, col)表示计算元素的矩阵索引
int col = tx + bx * blockDim.x; //线程计算的元素所在的列,(row, col)表示计算元素的矩阵索引
int m = A->height; //A的行数
int n = A->width; //A的列数
int k = B->width; //B的列数
for (int i = 0; i < (n - 1) / TILE_WIDTH + 1; i++) {
//保证A的元素valid
if(row < m && i * TILE_WIDTH + tx < n) {
sharedA[ty][tx] = getElement(A, row, i * TILE_WIDTH + tx);
} else {
sharedA[ty][tx] = 0.0;
//保证B的元素valid
if (col < k && i * TILE_WIDTH + ty < n) {
sharedB[ty][tx] = getElement(B, i * TILE_WIDTH + ty, col);
} else {
// 等待block内所有线程读取数据到共享内存
__syncthreads();
for (int j = 0; j < TILE_WIDTH; j++) {
Cvalue += sharedA[ty][j] * sharedB[j][tx];
// 等待block内所有线程计算得到
__syncthreads();
if (row < m && col < k) {
setElement(C, row, col, Cvalue);
int main(void)
// 1、设置GPU设备
setGPU();
// 2、分配主机内存和设备内存,并初始化
int width = 1 << 10;
int height = 1 << 10;
Matrix *A, *B, *C;
// 申请托管内存
cudaMallocManaged((void**)&A, sizeof(Matrix));
cudaMallocManaged((void**)&B, sizeof(Matrix));
cudaMallocManaged((void**)&C, sizeof(Matrix));
int nBytes = width * height * sizeof(float);
cudaMallocManaged((void**)&A->elements, nBytes);
cudaMallocManaged((void**)&B->elements, nBytes);
cudaMallocManaged((void**)&C->elements, nBytes);
// 初始化数据
A->height = height;
A->width = width;
B->height = height;
B->width = width;
C->height = height;
C->width = width;
for (int i = 0; i < width * height; ++i)
    A->elements[i] = 1.0;
    B->elements[i] = 2.0;
// 定义kernel的执行配置
dim3 blockSize(TILE_WIDTH, TILE_WIDTH);
dim3 gridSize((width + blockSize.x - 1) / blockSize.x,
    (height + blockSize.y - 1) / blockSize.y);
// 执行kernel
tiledMatMulKernel <<< gridSize, blockSize >>>(A, B, C);
// 同步device 保证结果能正确访问
cudaDeviceSynchronize();
// 检查执行结果
float maxError = 0.0;
    maxError = fmax(maxError, fabs(C->elements[i] - 2 * width));
cout << "最大误差: " << maxError << endl;
return 0;
and here is the naive version
include
//using namespace std
struct Matrix
int width;
int height;
float *elements;
global void matMulKernel(Matrix *A, Matrix *B, Matrix *C)
float Cvalue = 0.0;
int row = threadIdx.y + blockIdx.y * blockDim.y;
int col = threadIdx.x + blockIdx.x * blockDim.x;
for (int i = 0; i < A->width; ++i)
Cvalue += getElement(A, row, i) * getElement(B, i, col);
int main(void)
// 1、设置GPU设备
setGPU();
Matrix *A, *B, *C;
// 申请托管内存
// 初始化数据
A->height = height;
A->width = width;
B->height = height;
B->width = width;
C->height = height;
C->width = width;
// 定义kernel的执行配置
dim3 blockSize(32, 32);
// 执行kernel
matMulKernel << < gridSize, blockSize >> >(A, B, C);
// 检查执行结果
return 0;
when i compile the code and run on google colab with nvprof, i found no difference.
can anyone help to figure out why?
please format your code properly:
  1. edit your post by clicking the pencil icon below it
  2. select the code
  3. click the </> button at the top of the edit window
  4. save your changes
