We don’t have any implementation about KLV metadata. Please share more information about this.
1 What is the gstreamer elements for KLV metadta?
2 Please share a sample pipeline of generating KLV metadata in h264 stream, and a pipeline of extracting the metadta from the h264 stream.
We need more detail to understand this function and then check if we can customize deepstream-app to have the function. Let’s see if we can work out a solution.
We don’t have motivation of using KLV in DeepStrram SDK. Would suggest you use existing implementation nvdsmeta which collects the result of deep learning inference. Please check the sample:
