DeepStream 4.0 + Custom Yolo Model - App run failed
Hey, I’m using DeepStream 4.0 with Nvidia Jetson Nano device. I followed the guide available at https://docs.nvidia.com/metropolis/deepstream/4.0/Custom_YOLO_Model_in_the_DeepStream_YOLO_App.pdf to create a custom Yolov3-tiny Model but every time I run it, it crashed and gives error.
First, I followed the README.md available inside objectDetection_Yolo/ folder and ran the model on default configuration of yolov3-tiny.cfg and yolov3-tiny.weights, it works fine but when I try my already trained custom model it crashed with the error
Using winsys: x11
Creating LL OSD context new
0:00:00.825594078 22645      0xe89ea10 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:00.826501235 22645      0xe89ea10 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 not supported by platform. Trying FP16 mode.
Yolo type is not defined from config file name:yolo.cfg
0:00:00.826751710 22645      0xe89ea10 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Failed to create network using custom network creation function
0:00:00.826801763 22645      0xe89ea10 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Failed to create engine from model files
0:00:00.827080311 22645      0xe89ea10 WARN                 nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Failed to create NvDsInferContext instance
0:00:00.827113541 22645      0xe89ea10 WARN                 nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Config file path: /opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_Yolo/config_infer_primary_yoloV3_tiny.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie_classifier: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
App run failed
deepstream-app version 4.0
DeepStreamSDK 4.0
CUDA Version: 10.0
<i><b>config_infer_primary_yoloV3_tiny.txt</b></i>
[property]
gpu-id=0
net-scale-factor=1
#0=RGB, 1=BGR
model-color-format=0
custom-network-config=yolo.cfg
model-file=yolo_final.weights
#model-engine-file=model_b1_fp32.engine
labelfile-path=classnames.txt
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=114
gie-unique-id=1
is-classifier=0
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV3Tiny
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
<b><i>deepstream_app_config_yoloV3_tiny.txt</i></b>
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=2
uri=file://../../samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3_tiny.txt
[tests]
file-loop=0
I have a custom Yolo model build upon yolov3-tiny.
The error message is this:
Have you changed the architecture of YOLOv3 tiny.
Would you mind to check if there is some layer named as “YOLO” inside your customized model?
Thank you for your reply
Yes, I have modified the architecture of Yolov3-tiny and yes there is a layer named “YOLO” in my customized model.
Thanks for the help, I solved the problem but now I’m facing a different problem, I’m not able to run MultiURI with custom yolo model. When I try this is the error that I get
Using winsys: x11
Deserialize yoloLayerV3 plugin: yolo_17
Deserialize yoloLayerV3 plugin: yolo_24
Deserialize yoloLayerV3 plugin: yolo_31
Quitting
ERROR from source: Resource not found.
Debug info: gstfilesrc.c(533): gst_file_src_start (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstFileSrc:source:
No such file "/home/cec/Downloads/sample_video.mkv file:///home/cec/Downloads/sample_video.mkv file:///home/cec/Downloads/sample_video.mkv"
ERROR from source: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesrc.c(3452): gst_base_src_start (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstFileSrc:source:
Failed to start
Failed to start
App run failed
deepstream_app_config_yolov3_tiny.txt
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///home/cec/Downloads/sample_video.mkv file:///home/cec/Downloads/sample_video.mkv file:///home/cec/Downloads/sample_video.mkv
num-sources=16
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
model-engine-file=model_b1_fp16.engine
batch-size=1
gie-unique-id=1
nvbuf-memory-type=0
[tests]
file-loop=0
Please noticed you will need to declare the MultiURI argument with this rule:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/index.html#page/DeepStream_Development_Guide%2Fdeepstream_app_config.3.2.html%23wwpID0E0QB0HA
With MultiURI, the %d format specifier can also be used to specify multiple sources. The application iterates from 0 to num-sources 1 to generate the actual URIs.
uri=file:///home/ubuntu/source_%d.mp4
just solved it.
you are trying to use your customized weights right?
if this is the case, instead of changing the name of the weights file in the “config_infer_primary_yoloV3_tiny.txt” file, change the name of your yolo weight itself. so you should have a file named “yolov3-tiny.cfg” and another file named “yolov3-tiny.weights”. pay attention that these are not the files that are downloaded by running “prebuild.sh”, these are our own weights! we just changed their names!
Thank you man.
Your config file must have yolov3-* or yolov2-* name.
Hi guys,
@AastaLLL @anon56193499
Does Yolov5 or Yolov4 work on Deepstream?
I don’t think so DeepStream only supports till yolov3
