Current bindings are missing bindings for NvDsComp_BboxInfo, but you can create your own bindings by following the similar steps posted in this github page, https://github.com/mrtj/pyds_tracker_meta, please replace pyds_tracker_meta with the following code in pyds_bbox_meta.cpp and also make sure you do similarly in setup.py before making the build.
#include <pybind11/pybind11.h>
#include <pybind11/stl.h>
#include "nvdsmeta.h"
#include <iostream>
#include "nvll_osd_struct.h"
using namespace std;
namespace py = pybind11;
PYBIND11_MODULE(pyds_bbox_meta, m) {
m.doc() = "pybind11 wrapper to access Nvidia DeepStream detector bbox";
#define STRING_CHAR_ARRAY(TYPE, FIELD) \
[](const TYPE &self)->string { \
return string(self.FIELD); \
[](TYPE &self, std::string str) { \
int strSize = str.size(); \
str.copy(self.FIELD, strSize); \
py::return_value_policy::reference
py::class_<NvDsObjectMeta>(m,"NvDsObjectMeta",py::module_local())
.def(py::init<>())
.def_readwrite("base_meta", &NvDsObjectMeta::base_meta)
.def_readwrite("parent", &NvDsObjectMeta::parent)
.def_readwrite("unique_component_id", &NvDsObjectMeta::unique_component_id)
.def_readwrite("class_id", &NvDsObjectMeta::class_id)
.def_readwrite("object_id", &NvDsObjectMeta::object_id)
.def_readwrite("detector_bbox_info",&NvDsObjectMeta::detector_bbox_info)
.def_readwrite("tracker_bbox_info",&NvDsObjectMeta::tracker_bbox_info)
.def_readwrite("confidence", &NvDsObjectMeta::confidence)
.def_readwrite("tracker_confidence",&NvDsObjectMeta::tracker_confidence)
.def_readwrite("rect_params", &NvDsObjectMeta::rect_params)
.def_readwrite("mask_params",&NvDsObjectMeta::mask_params)
.def_readwrite("text_params", &NvDsObjectMeta::text_params)
.def("cast",[](void *data) {
return (NvDsObjectMeta*)data;},
py::return_value_policy::reference)
.def_property("obj_label", STRING_CHAR_ARRAY(NvDsObjectMeta, obj_label))
.def_readwrite("classifier_meta_list", &NvDsObjectMeta::classifier_meta_list)
.def_readwrite("obj_user_meta_list", &NvDsObjectMeta::obj_user_meta_list)
.def_property("misc_obj_info",
[](NvDsObjectMeta &self)->py::array {
auto dtype=py::dtype(py::format_descriptor<int>::format());
auto base=py::array(dtype, {MAX_USER_FIELDS}, {sizeof(int)});
return py::array(dtype,{MAX_USER_FIELDS}, {sizeof(int)}, self.misc_obj_info,base);
}, [](NvDsObjectMeta& self){})
.def_property("reserved",
auto base=py::array(dtype, {MAX_RESERVED_FIELDS}, {sizeof(int)});
return py::array(dtype,{MAX_RESERVED_FIELDS}, {sizeof(int)}, self.reserved,base);
}, [](NvDsObjectMeta& self){});
py::class_<NvOSD_RectParams>(m,"NvOSD_RectParams",py::module_local())
.def(py::init<>())
.def_readwrite("left",&NvOSD_RectParams::left)
.def_readwrite("top",&NvOSD_RectParams::top)
.def_readwrite("width",&NvOSD_RectParams::width)
.def_readwrite("height",&NvOSD_RectParams::height)
.def_readwrite("border_width",&NvOSD_RectParams::border_width)
.def_readwrite("border_color",&NvOSD_RectParams::border_color)
.def_readwrite("has_bg_color",&NvOSD_RectParams::has_bg_color)
.def_readwrite("reserved",&NvOSD_RectParams::reserved)
.def_readwrite("bg_color",&NvOSD_RectParams::bg_color)
.def_readwrite("has_color_info",&NvOSD_RectParams::has_color_info)
.def_readwrite("color_id",&NvOSD_RectParams::color_id);
py::class_<NvDsComp_BboxInfo>(m,"NvDsComp_BboxInfo",py::module_local())
.def(py::init<>())
.def_readwrite("org_bbox_coords",&NvDsComp_BboxInfo::org_bbox_coords);
py::class_<NvBbox_Coords>(m,"NvBbox_Coords",py::module_local())
.def(py::init<>())
.def_readwrite("left",&NvBbox_Coords::left)
.def_readwrite("top",&NvBbox_Coords::top)
.def_readwrite("width",&NvBbox_Coords::width)
.def_readwrite("height",&NvBbox_Coords::height);
Now using the built pyds_bbox_meta.so, you can get detector_bbox_info using the following code
obj_meta=pyds_bbox_meta.NvDsObjectMeta.cast(l_obj.data)
det_info_left = obj_meta.detector_bbox_info.org_bbox_coords.left
det_info_top = obj_meta.detector_bbox_info.org_bbox_coords.top
you can follow the similar procedure for creating and getting tracker bbox info as well.
