• Hardware Platform (Jetson / GPU) Jetson Nano 2GB • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
./deepstream-test5-analytics -c config/test5_config_file_src_infer_tlt.txt
** WARN: <parse_source:577>: Deprecated config ‘smart-rec-video-cache’ used in group [source1]. Use ‘smart-rec-cache’ instead
** ERROR: <create_msg_conv_broker_bin:234>: Failed to create ‘sink_sub_bin_transform1’
** ERROR: <create_msg_conv_broker_bin:278>: create_msg_conv_broker_bin failed
** ERROR: <create_sink_bin:781>: create_sink_bin failed
** ERROR: <create_processing_instance:815>: create_processing_instance failed
** ERROR: <create_pipeline:1323>: create_pipeline failed
** ERROR: main:1041: Failed to create pipeline
Quitting
App run failed
Factory Details:
Rank primary (256)
Long-name Message Broker
Klass Sink/Metadata
Description Sends payload metadata to remote server
Author NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries @ DeepStream SDK - NVIDIA Developer Forums
