• Hardware Platform (Jetson / GPU) ubuntu-22.04.1-desktop-amd64
• DeepStream Version 6.1.1
• TensorRT Version 8.5.1
• NVIDIA GPU Driver Version (valid for GPU only) Driver Version: 515.65.01 CUDA Version: 11.7
• Issue Type( questions, new requirements, bugs) questions
I can recreate it every time. Maybe it’s the compiler version?
I’m a c++ novice. I found this article.
why-cant-templates-be-within-extern-c-blocks
Here is the program output
(base) lxy@lxy:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app$ ls
deepstream_app.c deepstream_app_config_parser_yaml.cpp deepstream_app_main.c README
deepstream_app_config_parser.c deepstream_app.h Makefile
(base) lxy@lxy:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app$ sudo make
cc -c -o deepstream_app.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include deepstream_app.c
deepstream_app.c: In function ‘create_pipeline’:
deepstream_app.c:1133:7: warning: ‘gst_element_get_request_pad’ is deprecated: Use 'gst_element_request_pad_simple' instead [-Wdeprecated-declarations]
1133 | demux_src_pad = gst_element_get_request_pad (pipeline->demuxer, pad_name);
In file included from /usr/include/gstreamer-1.0/gst/gstbin.h:27,
from /usr/include/gstreamer-1.0/gst/gst.h:35,
from deepstream_app.c:23:
/usr/include/gstreamer-1.0/gst/gstelement.h:1042:25: note: declared here
1042 | GstPad* gst_element_get_request_pad (GstElement *element, const gchar *name);
deepstream_app.c:1227:7: warning: ‘gst_element_get_request_pad’ is deprecated: Use 'gst_element_request_pad_simple' instead [-Wdeprecated-declarations]
1227 | demux_src_pad = gst_element_get_request_pad(pipeline->demuxer, pad_name);
cc -c -o deepstream_app_config_parser.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include deepstream_app_config_parser.c
cc -c -o deepstream_app_main.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include deepstream_app_main.c
g++ -c -o deepstream_app_config_parser_yaml.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include deepstream_app_config_parser_yaml.cpp
cc -c -o ../../apps-common/src/deepstream_audio_classifier_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_audio_classifier_bin.c
cc -c -o ../../apps-common/src/deepstream_c2d_msg.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_c2d_msg.c
cc -c -o ../../apps-common/src/deepstream_c2d_msg_util.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_c2d_msg_util.c
cc -c -o ../../apps-common/src/deepstream_common.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_common.c
../../apps-common/src/deepstream_common.c: In function ‘link_element_to_streammux_sink_pad’:
../../apps-common/src/deepstream_common.c:85:3: warning: ‘gst_element_get_request_pad’ is deprecated: Use 'gst_element_request_pad_simple' instead [-Wdeprecated-declarations]
85 | mux_sink_pad = gst_element_get_request_pad (streammux, pad_name);
from ../../apps-common/src/deepstream_common.c:23:
../../apps-common/src/deepstream_common.c: In function ‘link_element_to_demux_src_pad’:
../../apps-common/src/deepstream_common.c:167:3: warning: ‘gst_element_get_request_pad’ is deprecated: Use 'gst_element_request_pad_simple' instead [-Wdeprecated-declarations]
167 | demux_src_pad = gst_element_get_request_pad (demux, pad_name);
cc -c -o ../../apps-common/src/deepstream_config_file_parser.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_config_file_parser.c
cc -c -o ../../apps-common/src/deepstream_dewarper_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_dewarper_bin.c
cc -c -o ../../apps-common/src/deepstream_dsanalytics.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_dsanalytics.c
cc -c -o ../../apps-common/src/deepstream_dsexample.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_dsexample.c
cc -c -o ../../apps-common/src/deepstream_osd_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_osd_bin.c
cc -c -o ../../apps-common/src/deepstream_perf.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_perf.c
cc -c -o ../../apps-common/src/deepstream_preprocess.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_preprocess.c
cc -c -o ../../apps-common/src/deepstream_primary_gie_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_primary_gie_bin.c
cc -c -o ../../apps-common/src/deepstream_secondary_gie_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_secondary_gie_bin.c
cc -c -o ../../apps-common/src/deepstream_sink_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_sink_bin.c
cc -c -o ../../apps-common/src/deepstream_source_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_source_bin.c
cc -c -o ../../apps-common/src/deepstream_streammux.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_streammux.c
cc -c -o ../../apps-common/src/deepstream_tiled_display_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_tiled_display_bin.c
cc -c -o ../../apps-common/src/deepstream_tracker_bin.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream_tracker_bin.c
g++ -c -o ../../apps-common/src/deepstream-yaml/deepstream_config_yaml.o -I./ -I../../apps-common/includes -I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 -I /usr/local/cuda-11.7/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/orc-0.4 -I/usr/include/gstreamer-1.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/json-glib-1.0 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include ../../apps-common/src/deepstream-yaml/deepstream_config_yaml.cpp
In file included from /usr/include/glib-2.0/glib/glib-typeof.h:39,
from /usr/include/glib-2.0/glib/gatomic.h:28,
from /usr/include/glib-2.0/glib/gthread.h:32,
from /usr/include/glib-2.0/glib/gasyncqueue.h:32,
from /usr/include/glib-2.0/glib.h:32,
from /usr/include/gstreamer-1.0/gst/gst.h:27,
from ../../apps-common/includes/deepstream_common.h:31,
from ../../apps-common/src/deepstream-yaml/deepstream_config_yaml.cpp:23:
/usr/include/c++/11/type_traits:44:3: error: template with C linkage
44 | template<typename... _Elements>
In file included from ../../apps-common/src/deepstream-yaml/deepstream_config_yaml.cpp:23:
../../apps-common/includes/deepstream_common.h:27:1: note: ‘extern "C"’ linkage started here
27 | extern "C"
/usr/include/c++/11/type_traits:47:3: error: template with C linkage
47 | template<typename _Tp>
27 | extern "C"
/usr/include/c++/11/type_traits:64:3: error: template with C linkage
64 | template<typename _Tp, _Tp __v>
27 | extern "C"
/usr/include/c++/11/type_traits:79:3: error: template with C linkage
79 | template<typename _Tp, _Tp __v>
27 | extern "C"
/usr/include/c++/11/type_traits:90:3: error: template with C linkage
90 | template<bool __v>
27 | extern "C"
/usr/include/c++/11/type_traits:98:3: error: template with C linkage
98 | template<bool __v>
27 | extern "C"
/usr/include/c++/11/type_traits:104:3: error: template with C linkage
104 | template<bool, typename, typename>
27 | extern "C"
/usr/include/c++/11/type_traits:108:3: error: template with C linkage
108 | template <typename _Type>
27 | extern "C"
/usr/include/c++/11/type_traits:112:3: error: template with C linkage
112 | template<typename _Tp>
27 | extern "C"
/usr/include/c++/11/type_traits:115:3: error: template with C linkage
115 | template<typename...>
27 | extern "C"
/usr/include/c++/11/type_traits:118:3: error: template specialization with C linkage
118 | template<>
27 | extern "C"
/usr/include/c++/11/type_traits:123:3: error: template with C linkage
123 | template<typename _B1>
27 | extern "C"
/usr/include/c++/11/type_traits:128:3: error: template with C linkage
128 | template<typename _B1, typename _B2>
27 | extern "C"
/usr/include/c++/11/type_traits:133:3: error: template with C linkage
133 | template<typename _B1, typename _B2, typename _B3, typename... _Bn>
27 | extern "C"
/usr/include/c++/11/type_traits:138:3: error: template with C linkage
138 | template<typename...>
27 | extern "C"
/usr/include/c++/11/type_traits:3294:3: error: template with C linkage
3294 | template<typename _Tp>
27 | extern "C"
/usr/include/c++/11/type_traits:3300:3: error: template with C linkage
3300 | template<typename _Tp>
27 | extern "C"
make: *** [Makefile:72: ../../apps-common/src/deepstream-yaml/deepstream_config_yaml.o] Error 1
