## [DeepStream 7.1 / Jetson Orin Nano / JetPack 6.x] Pipeline freeze with old `nvstreammux` and multiple live sources
[DeepStream 7.1 / Jetson Orin Nano / JetPack 6.x] Pipeline freeze with old nvstreammux and multiple live sources
Scenario
I am running a DeepStream pipeline on Jetson Orin Nano devices with JetPack 6.x.
The issue has been reproduced on both hardware configurations:
Hardware JetPack / L4T
Jetson Orin Nano 4GB JetPack 6.x / L4T 36.4.3
Jetson Orin Nano 8GB JetPack 6.x / L4T 36.4.3
Software stack:
Component Version
DeepStream 7.1
GStreamer 1.20.3
OS Ubuntu 22.04
Stream muxer Old nvstreammux
Tracker nvtracker with NvDCF tracker
The same application logic and equivalent pipeline configuration were stable on:
DeepStream 6.3 / JetPack 5.x / GStreamer 1.16.3
The freeze started appearing after moving to:
DeepStream 7.1 / JetPack 6.x / GStreamer 1.20.3
Use case
The application processes multiple live video sources at the same time.
The sources are mixed protocols:
  • HTTP streams using souphttpsrc
  • RTSP streams using rtspsrc
Each source is decoded, converted, batched with old nvstreammux, processed by inference and tracking, then demuxed again and sent to an appsink.
Simplified pipeline:
[souphttpsrc / rtspsrc]
    [decodebin]
[nvvideoconvert]
  compute-hw=1
[old nvstreammux]
  live-source=TRUE
  batch-size=N
    [nvinfer]
[nvtracker - NvDCF]
 [nvstreamdemux]
[queue] -> [nvvideoconvert] -> [appsink]
There is no queue between nvstreammux and nvinfer.
Problem description
After a variable runtime, usually within a few hours, the pipeline enters a permanent frozen state.
The issue has been observed when more than two live sources are active simultaneously.
Observed behavior:
  • all streams freeze at the same time;
  • all queues downstream of nvstreamdemux fill up to their maximum size almost simultaneously;
  • after the queues are full, no more frames are produced;
  • appsink callbacks are no longer called;
  • no useful errors or messages are posted on the GStreamer bus;
  • the issue does not seem related to a single source, because it happens simultaneously across HTTP and RTSP streams.
Example of the observed behavior:
[T+0s] queue_0: 0 buffers / 0ms
[T+3s] queue_0: 75 buffers / 5000ms
[T+3s] queue_1: 75 buffers / 5000ms
[T+3s] queue_2: 75 buffers / 5000ms
# From this point on, there is no further pipeline activity
Since all queues saturate at the same time, across different source protocols, the issue appears to be in the shared part of the pipeline:
nvstreammux -> nvinfer -> nvtracker -> nvstreamdemux
rather than in a single source branch.
Diagnostics performed
I added a GST_PAD_PROBE_TYPE_BUFFER probe on the src pad of nvstreammux.
During normal operation:
the probe receives batches every 40–80 ms
Occasionally, small gaps are observed:
200–300 ms
but the pipeline recovers correctly.
When the freeze occurs:
the probe on the nvstreammux src pad completely stops receiving buffers
The pipeline formally remains in PLAYING state, but nvstreammux no longer produces output batches.
Also, calling the following from a separate thread:
gst_element_set_state(pipeline, GST_STATE_NULL);
stops the pipeline correctly in around 250 ms.
This suggests that it is not a full GStreamer state deadlock, but rather a stall in the streaming data path or in batch production.
Workarounds already applied
The following workarounds have already been applied.
1. nvvideoconvert with compute-hw=1
Without this setting, the pipeline fails with errors like:
nvbufsurftransform_copy.cpp: Failed in mem copy
Applied workaround:
g_object_set(nvvideoconvert, "compute-hw", 1, NULL);
2. Disabled souphttpsrc timeout
To avoid disconnections caused by the default libsoup3 timeout:
g_object_set(souphttpsrc, "timeout", 0, NULL);
3. Live queues configured as leaky
To avoid blocking live source threads during downstream stalls:
g_object_set(vqueue, "leaky", 2, NULL);
4. Avoided gst_element_release_request_pad() on old nvstreammux while the pipeline is PLAYING
I observed that calling gst_element_release_request_pad() on old nvstreammux while the pipeline is running can cause a deadlock.
Applied workaround:
  • I do not release request pads while the pipeline is running;
  • when reconnecting a source, I reuse the existing pad if it already exists.
Questions
  1. Are there any known regressions in DeepStream 7.1 / JetPack 6.x with old nvstreammux, multiple live sources, and nvtracker using NvDCF?
  2. Are there known cases where old nvstreammux stops producing output batches while the pipeline remains in PLAYING state?
  3. With DeepStream 7.1 on Jetson, what are the recommended settings for old nvstreammux in live multi-source pipelines?
  4. Can nvtracker with NvDCF introduce backpressure or stalls that propagate back to nvstreammux in this kind of pipeline?
  5. What additional logs, probes, or debug environment variables do you recommend to diagnose this kind of freeze?
Additional notes
  • The same scenario was stable on DeepStream 6.3 / JetPack 5.x.
  • The issue has been reproduced on both Jetson Orin Nano 4GB and Jetson Orin Nano 8GB, both with L4T 36.4.3.
  • The issue occurs with both HTTP and RTSP sources.
  • The freeze is global and simultaneous across all streams.
  • Thermal throttling has been excluded using tegrastats.
  • Memory exhaustion has been excluded: RAM usage is stable at the time of the freeze.
Is this still a problem?
For multi-protocol streaming, I recommend uridecodebin.
Adding a queue between mux/demux is recommended.
Queue usage is recommended after nvstreammux to ensure batching operation does not happen in the same thread as that of the plugin downstream (say nvstreamdemux)
Queues are recommended after nvstreamdemux source pads. nvstreamdemux does not create additional threads inside. This is why a sizable queue between nvstreammux and nvstreamdemux is essential to de-couple them.
This is a known issue; DS-7.1 and JP-6.2 are not fully compatible. JP-6.1 is recommended for use with DS-7.1.
This problem shouldn’t occur; you can refer to this sample. deepstream_test_rt_src_add_del
No.
No.
Refer to the suggestions above
No, I haven’t observed anything like that.
The legacy nvstreammux is not currently open source. Besides the tips mentioned in the FAQ, you can try debugging the new nvstreammux(/opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvmultistream2), which is open source.
Ok, thank you
If i Downgrade the jetpack what is the main difference between JP6.2.2 and 6.1?
using nvvideoconvert with compute-hw=1 introducing any performance decreasing?
Regards
I don’t have much information on this; you might want to check the release notes.
For DeepStream 7.1, It was only tested on JP-6.1.
This will slightly increase GPU utilization.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
