Deepstream 7.1 test1 application error
• Hardware Platform (Jetson / GPU) 3050
• DeepStream Version 7.1
• TensorRT Version
Hi, I just installed deepstream, with python binding. I am running on deepstream-test1, and i got the following error:
Original exception was:
  File "/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py", line 50, in osd_sink_pad_buffer_probe
AttributeError: 'NoneType' object has no attribute 'frame_meta_list'
(python3:45002): GStreamer-CRITICAL **: 15:02:23.620: gst_meta_api_type_has_tag: assertion 'tag != 0' failed
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 118, in apport_excepthook
  File "/usr/lib/python3/dist-packages/apport/report.py", line 602, in add_proc_info
OSError: [Errno 24] Too many open files: '/proc/45002'
I tried running the h264 file with gstreamer and is working fine
gst-launch-1.0 filesrc location=video.h264 ! h264parse ! avdec_h264 ! autovideosink
Please advise
Please install DeepStreamSDK and pyds correctly.
It is recommended that you use docker, after installing nvidia-container-toolkit
docker run --gpus all -it --rm --network=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-7.1 nvcr.io/nvidia/deepstream:7.1-gc-triton-deve
./user_deepstream_python_apps_install.sh --build-bindings -r v1.2.0
