When I run deepstream-test1, a box named Python pops up and immediately close it by itself. the consle
**• Hardware Platform (Jetson / GPU) RTX4060
**• DeepStream Version7.0
**• JetPack Version (valid for Jetson only)ubuntu22.04
**• TensorRT Version 10.0.0
**• NVIDIA GPU Driver Version (valid for GPU only) 550.78
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
(python3:66369): GStreamer-CRITICAL **: 14:30:06.603: gst_meta_api_type_has_tag: assertion ‘tag != 0’ failed
l_frame = batch_meta.frame_meta_list
AttributeError: ‘NoneType’ object has no attribute ‘frame_meta_list’
End-of-stream
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
This problem is caused by pyds and dependencies not being installed correctly ,Please follow this link to install pyds.
thanks your reply
but after i follow this link to install pyds , i run deepstream-test1 ,this problem still exists.
(python3:11010): GStreamer-CRITICAL **: 11:17:18.872: gst_meta_api_type_has_tag: assertion ‘tag != 0’ failed
Noticed you are using the TRT 10.0 which is not compatible with deepstream 7.0.
If you don’t want to reinstall TensorRT, it is recommended to use docker
