Deepstream composer pipeline debug
GPU
• DeepStream Version
6.1
• TensorRT Version
8.4.1
515.48.07
Question
I created a deepstream application using the graph composer tool. The pipeline reads a video file and performs chained inferences on each frame. At the end of my pipeline I have an OSD and a Rendering component and I am able to see the output of my application in a window. However, I would like to be able to see the metadata added by each inference component. My first thought was I should add a probe and connect it to the output of the first inference component, a probe which would just dump the metadata in the console. I was unable to find a probe that is able to do this for me and I am not sure what should I do now. Should I try to create a custom extension that dumps the metadata described here or what is a go-to method in my situation?
Thank you
Yes. You need a customized extension for the probe function.
