• Hardware Platform (GPU)
• DeepStream Version 6.3
• NVIDIA GPU Driver Version 535
• Issue Type: bugs
• How to reproduce the issue ?
I am testing the new MQTT message broker feature of DeepStream 6.3.
I modified the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt sample configuration to use a live stream from a RTSP camera. I added a sink3 to be used to connect the deepstream-test5-app to a Mosquitto MQTT broker running locally on default port 1883.
The sink3 part of the config file looks like this:
[sink3]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=msgconv_config_empty.txt
disable-msgconv=0 # set to 0 to enable msgconv, which convert the NVEVENT metadata from primary/secondary GIE into mqtt message
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_mqtt_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=127.0.0.1;1883
topic=test
#Optional:
config=cfg_mqtt.txt
The cfg_mqtt.txt contains:
[message-broker]
username = user
password = password
#share-connection = 1
#loop-timeout = 2000
The example is working as expected (sending JSON messages to the MQTT broker) - but only as long as there are objects detected within a certain period of time. When it takes too long (e.g. more than 60 seconds) until a detectable object appears in the video, the app terminates in that moment, where a new object was detected.
The error message in the console is:
Error sending repeat publish: The client is not currently connected.ERROR from sink_sub_bin_sink3: GStreamer encountered a general supporting library error.
Debug info: gstnvmsgbroker.cpp(537): legacy_gst_nvmsgbroker_render (): /GstPipeline:pipeline/GstBin:sink_sub_bin3/GstNvMsgBroker:sink_sub_bin_sink3:
failed to send the message. err(1)
So it looks like there is no automatic reconnection done by the client, when the previous connection to the message broker has timed out.
This error is not handled, so the app terminates completely.
I also played around with share-connection (uncommented and so set to 1) and a loop-timeout = 60000 but the problem cannot be solved using these parameters.
