NVIDIA Jetson Xavier AGX
• DeepStream Version
5.0
jetpack 4.4
• TensorRT Version
7.1
N/A
Questions
run the deepstream-test5, but with a different broker running than rabbitmq.
In my case I am running ActiveMQ v5.16 on my local machine, and the broker has been verified to be up and running properly on the correct ip/port however I am unable to connect.
I am trying to see if deepstream supports message broker software’s that implement the AMQP protocol (other than rabbitMQ).
I have successfully set up rabbitMQ , ran deepstream-test4/deepstream-test5 and verified they worked perfectly.
however I need to be using ActiveMQ as my message broker software.
deepstream-test5:(output)
(deepstream-test5-app:11542): GLib-CRITICAL **: 15:01:21.062: g_strchug: assertion 'string != NULL' failed
(deepstream-test5-app:11542): GLib-CRITICAL **: 15:01:21.062: g_strchomp: assertion 'string != NULL' failed
(deepstream-test5-app:11542): GLib-CRITICAL **: 15:01:21.148: g_strrstr: assertion 'haystack != NULL' failed
** ERROR: <main:1451>: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink2: Could not configure supporting library.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
unable to connect to broker library
ERROR from sink_sub_bin_sink2: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
Failed to start
App run failed
cfg_amqp.txt:
#ActiveMQ settings
[message-broker]
password = admin
hostname = localhost
username = admin
port = 61616
exchange = amq.topic
topic = topicname
#share-connection = 1
#Rabbit MQ settings
#[message-broker]
#password = guest
#hostname = localhost
#username = guest
#port = 5672
#exchange = amq.topic
#topic = topicname
##share-connection = 1
test5_config_file_src_infer.txt:
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_amqp_proto.so
#Provide your msg-broker-conn-str here
##msg-broker-conn-str=;;
##topic=
#Optional:
msg-broker-config=…/…/deepstream-test4/cfg_amqp.txt
any help would be greatly appreciated!
Thanks,
ws
