Jetson Nano
• DeepStream Version
5.0
4.4
• TensorRT Version
7.0?
• Sample application and the configuration file content
deepstream-app
Config file main part:
[sink0]
enable=1
type=6
source-id=0
gpu-id=0
msg-conv-config=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test5/configs/dstest5_msgconv_sample_config.txt
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_amqp_proto.so
msg-broker-conn-str=192.168.1.2;5678;mqtt-test;mqtt-test
topic=test
msg-conv-payload-type=0
• Reproduce steps
Run any model with the above sink
• Reproducing rate and duration
Every time
Problem: I can’t see the output when I subscribe to the AMQP topic. I’ve used the rabbitmq-c clients and they work perfectly fine. I’ve also used the sources/lib/amqp_protocol_adapter files and they work as well. I’m able to receive messages sent by those. I’m not able see the messages sent by deepstream. How do I fix this?
Thank you!
