• Hardware Platform (Jetson / GPU) H100
• DeepStream Version
• TensorRT Version
Hi there, I am using the deepstream lpr app with 5 RTSP stream. If there is one RTSP was disconnected, the application tends to exits. How can i remove the stream without exiting the app. Besides, thinking about adding the stream, what if i have a 6th stream to be added while the application is running, is it possible for the application to add the stream and start inference without restarting?
