DeepStream RTSP FPS Drop in Docker – Performance Issue
• Hardware Platform (Jetson / GPU) - GPU (A4000)
• DeepStream Version - 7.1
• TensorRT Version - 10.8.0.43-1
• NVIDIA GPU Driver Version (valid for GPU only) - 550
I’m experiencing a significant FPS drop while running multiple RTSP streams using DeepStream in Docker. Below is a brief of my setup:
Docker Image: nvcr.io/nvidia/deepstream:7.1-gc-triton-devel
Streams: 8 RTSP streams
Pipeline:
streammux → pgie → tracker → sgie1 → sgie2 → sgie3 → nvvidconv1 → filter1 → nvanalytics → tiler → nvvidconv → nvosd → tee
tee → queue1 → msgconv → msgbroker
→ queue2 → nvvidconv_postosd → caps → encoder → rtppay → sink
At the start, I get around 21–22 FPS per stream, but over time it drops drastically to 5–6 FPS.
But, when I run the same pipeline locally (outside Docker), I start at 25–27 FPS per stream and it gradually drops to 17–18 FPS.
How can i debug the bottleneck?
Have you monitored the GPU loading and CPU loading when the FPS dropped?
There are 3 SGIEs in your pipeline, the SGIEs may run on objects detected by PGIE, have you measured the models’ performance on A4000?
You can measure the model’s performance with “trtexec” tool.
You may refer to Low performance when running pipeline with RTX 4090 - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
