T4
• DeepStream Version
5.0
NA
• TensorRT Version
7.0.0.11
440.64.00
I am running two separate DeepStream-python processes (each one in a separate docker container) on a single VM with a T4 GPU. Separately each process is able to process at 90 fps when running alone. But when both containers are running, both the streams seem to slowdown drastically and run at 20-25 fps. Is there any known issue with multiple DeepStream processes running on the same GPU? How do I proceed with the debugging of this issue?
