Running Deepstream in Docker container decreasing FPS
When I run deepstream app in docker container it decreases FPS. I am using RSTP stream as input. I check stats and it is not utilising GPU properly. GPU utilisation reached 100% in a second and remains 0% in consecutive seconds.
• DeepStream Version
• TensorRT Version
Do you use the same deepstream sample or command for this?
If yes, could you share the detailed with us so we can reproduce this in our environment?
