DeepStream run multiple engines image flicker
Why when I run multiple engine models on multiple deepstream5.0 instances, each instance runs multiple cameras, and the rtsp stream of the camera in each instance will continuously flicker the images from other cameras ,and the higher the GPU occupancy, the picture flickers Faster, even if I run multiple deepstream instances on multiple GPUs, the situation is the same.
**• Hardware Platform (Jetson / GPU)Tesla T4
**• DeepStream Version 5.0
**• TensorRT Version 7.0.0
**• NVIDIA GPU Driver Version (valid for GPU only)10.2
i think the “flicker” problem is related to your udp sink port, please check if the port are distinct or not
thanks,I have solved this problem due to a bug in deepstream5.0 version
Great work, please create new topic if you need any help.
