• Hardware Platform (Jetson / GPU) 4090
• DeepStream Version 7.0
• TensorRT Version 8.6.1
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
related question:** https://forums.developer.nvidia.com/t/discrepancy-between-pytorch-and-deepstream-inference-when-deploying-a-custom-reid-model/346211/5
I use the Python backend with Triton and nvinferserver instead of nvinfer so that I can customize the preprocessing and output to be equivalent to PyTorch. When testing with Triton through the HTTP API, Triton works fine, but when integrating with DeepStream, I couldn’t find a sample example and encountered the following error.
The steps I followed are as follows:
model.py
import numpy as np
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
import triton_python_backend_utils as pb_utils
import torch
from torchvision.ops import roi_align
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
class TritonPythonModel:
def initialize(self, args):
engine_path = "/app/models/mgn/1/model.plan"
with open(engine_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
self.engine = runtime.deserialize_cuda_engine(f.read())
self.context = self.engine.create_execution_context()
self.mean = torch.tensor([0.485, 0.456, 0.406]).view(3, 1, 1)
self.std = torch.tensor([0.229, 0.224, 0.225]).view(3, 1, 1)
# Get I/O names
self.input_name = None
self.output_name = None
for i in range(self.engine.num_io_tensors):
name = self.engine.get_tensor_name(i)
if self.engine.get_tensor_mode(name) == trt.TensorIOMode.INPUT:
self.input_name = name
else:
self.output_name = name
if not self.input_name or not self.output_name:
raise ValueError("Missing input/output tensor")
# We'll set input shape dynamically per batch size
self.max_batch_size = 4 # must match config.pbtxt
self.fixed_hw = (384, 128)
# Get output shape for batch=1
self.context.set_input_shape(self.input_name, (1, 3, *self.fixed_hw))
self.single_output_shape = self.context.get_tensor_shape(self.output_name) # e.g., (2048,)
self.input_dtype = trt.nptype(self.engine.get_tensor_dtype(self.input_name))
self.output_dtype = trt.nptype(self.engine.get_tensor_dtype(self.output_name))
self.stream = cuda.Stream()
# Pre-allocate max memory (for batch=4)
max_input_elements = self.max_batch_size * 3 * self.fixed_hw[0] * self.fixed_hw[1]
max_output_elements = self.max_batch_size * trt.volume(self.single_output_shape)
self.input_host = np.empty(max_input_elements, dtype=self.input_dtype)
self.output_host = np.empty(max_output_elements, dtype=self.output_dtype)
self.input_device = cuda.mem_alloc(self.input_host.nbytes)
self.output_device = cuda.mem_alloc(self.output_host.nbytes)
self.context.set_tensor_address(self.input_name, int(self.input_device))
self.context.set_tensor_address(self.output_name, int(self.output_device))
def preprocess_batch(self, batch_img_arrays):
Preprocess a batch of images.
Args:
batch_img_arrays: list of numpy arrays, each (H, W, 3), uint8
Returns:
numpy array of shape (B, 3, 384, 128), dtype float32
preprocessed = []
for img_array in batch_img_arrays:
img = img_array.astype(np.float32) / 255.0
frame = torch.from_numpy(img).permute(2, 0, 1) # HWC -> CHW
frame = frame.sub_(self.mean).div_(self.std) # normalize
w, h = frame.shape[2], frame.shape[1]
cbboxes = np.array([[0, 0, w, h]], dtype=np.float32)
boxes = torch.cat([torch.zeros(1, 1), torch.from_numpy(cbboxes)], dim=1)
crop = roi_align(frame.unsqueeze(0), boxes, output_size=self.fixed_hw)
preprocessed.append(crop.squeeze(0).numpy())
return np.stack(preprocessed, axis=0).astype(self.input_dtype)
def execute(self, requests):
responses = []
for request in requests:
input_tensor = pb_utils.get_input_tensor_by_name(request, "input")
batch_input = input_tensor.as_numpy() # shape: (B, H, W, 3)
if batch_input.ndim == 3:
# Single image (no batch dim) — should not happen if max_batch_size > 0
batch_input = np.expand_dims(batch_input, axis=0)
batch_size = batch_input.shape[0]
if batch_size > self.max_batch_size:
err = pb_utils.TritonError(f"Batch size {batch_size} exceeds max {self.max_batch_size}")
responses.append(pb_utils.InferenceResponse(error=err))
continue
try:
# Preprocess entire batch
input_data = self.preprocess_batch([batch_input[i] for i in range(batch_size)])
# input_data shape: (B, 3, 384, 128)
# Set dynamic input shape
actual_input_shape = (batch_size, 3, *self.fixed_hw)
if not self.context.set_input_shape(self.input_name, actual_input_shape):
raise ValueError(f"Failed to set input shape {actual_input_shape}")
actual_output_shape = self.context.get_tensor_shape(self.output_name)
expected_output_elements = trt.volume(actual_output_shape)
if input_data.size > self.input_host.size:
raise ValueError("Input data too large for pre-allocated buffer")
# Copy to host buffer
np.copyto(self.input_host[:input_data.size], input_data.ravel())
# GPU copy and inference
cuda.memcpy_htod_async(self.input_device, self.input_host, self.stream)
self.context.execute_async_v3(stream_handle=self.stream.handle)
cuda.memcpy_dtoh_async(self.output_host, self.output_device, self.stream)
self.stream.synchronize()
# Reshape output
embedding = self.output_host[:expected_output_elements].copy().reshape(actual_output_shape)
embedding = embedding.astype(np.float32)
out_tensor = pb_utils.Tensor("output", embedding)
responses.append(pb_utils.InferenceResponse(output_tensors=[out_tensor]))
except Exception as e:
err = pb_utils.TritonError(f"Batch inference failed: {str(e)}")
return responses
def finalize(self):
self.input_device.free()
self.output_device.free()
config.pbtxt
backend: "python"
max_batch_size: 4 # hoặc giá trị bạn muốn
input [
data_type: TYPE_FP32
dims: [ -1, -1, 3 ] # H, W, C — Triton tự thêm batch dim ở đầu
output [
dims: [2048]
instance_group {
kind: KIND_GPU
count: 1
gpus: 0
version_policy: { specific: { versions: [1]}}
deepstream reid config
infer_config {
unique_id: 2
gpu_ids: [0]
max_batch_size: 4
backend {
triton {
model_name: "mgn"
version: -1
grpc {
url: "192.168.1.90:32001"
enable_cuda_buffer_sharing: true
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_NHWC
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 0
normalize {
scale_factor: 1.0
channel_offsets: [0.0,0.0,0.0]
postprocess {
labelfile_path: "labels.txt"
detection {
num_detected_classes: 1
custom_parse_bbox_func: "NvDsInferParseYolo"
extra {
copy_input_to_host_buffers: false
custom_lib {
path : "/nvdsinfer_custom_impl_mgn_triton/libnvdsinfer_custom_impl_Yolo.so"
input_control {
process_mode : PROCESS_MODE_CLIP_OBJECTS
operate_on_gie_id: 1
operate_on_class_ids: [0]
interval : 0
output_control {
output_tensor_meta: true
My deepstream base on nvcr.io/nvidia/deepstream:7.0-triton-multiarch so it has tensorrt 8.6.1
So when using triton with python backend. My dockerfile like this
# Sử dụng Triton server có sẵn Python backend (phiên bản 24.08)
# FROM nvcr.io/nvidia/tritonserver:24.08-py3
FROM nvcr.io/nvidia/tritonserver:23.10-py3
RUN apt-get update && apt-get install ffmpeg libsm6 libxext6 -y
# python lib
RUN PIP_INSTALL="pip --no-cache-dir install --upgrade" && \
$PIP_INSTALL \
opencv-python \
yacs \
pillow \
unidecode
# RUN pip install onnxruntime
# RUN pip install --upgrade tritonclient[all]
# RUN pip --no-cache-dir install \
# protobuf==3.20.0 \
# numpy==1.23.5
# RUN PIP_INSTALL="pip --no-cache-dir install --upgrade" && \
# $PIP_INSTALL \
# torch torchvision torchaudio
COPY requirements.txt .
RUN pip install --no-cache-dir -r requirements.txt
RUN pip install torch==2.7.0 torchvision==0.22.0 torchaudio==2.7.0 --index-url https://download.pytorch.org/whl/cu126
ENV LC_ALL C.UTF-8
requirements.txt
opencv-python
#tensorrt==10.3.0
tensorrt==8.6.1
pycuda
onnx
onnxslim
onnxruntime
tritonclient[all]
protobuf==3.20.0
numpy==1.23.5
yacs
pillow
unidecode
I using nvcr.io/nvidia/tritonserver:23.10-py3 : refence deepstream 7.0 release notes
Are there any mistakes in my steps, or does DeepStream support Triton with the Python backend? If so, could you provide me with an example link for reference? Thanks
