Deepstream with RTSP vs files
• Hardware Platform (Jetson / GPU) : NVIDIA GeForce RTX 3090
• DeepStream Version : 6.3
• TensorRT Version : 12.2
• NVIDIA GPU Driver Version (valid for GPU only) : 535.104.05
I am using deepstream-test3.py and added tracker and other models
I have 32 video files when run pipeline with these video files get objects count from 400 to 600 but when use tool to simulate these video to RTSP and pipeline we get objects count from 100 to 250
also we don’t set parameter batched-push-timeout
why these drop happened however used same videos
Could you print the total number of frames in those 2 scenarios?
You can also use just 1 video to compare.
I did test you mentioned on wild track video number 1 on file and also simulated as RTSP
Screenshot for test on video file
Screenshot for test simulate video file as RTSP stream
deepstream-test3 script we used to do this test
deepstream_test_3.txt (18.1 KB)
as you can see count of objects in video file greater than count of objects in RTSP stream however we are using same video so count should be the same
why this issue happened?
Appreciate your feedback
There may be recoding or packet loss when you use the RTSP.
1.You need to make sure that the video is not recoded when you use the rtsp.
2.You need to make sure there are no packet loss when you use rtsp.
I am using cvlc tool to simulate RTSP from videos on same server that has deepstream_test.py script so I think no network drops
or what do you think?
It cound lead to the two problems I mentioned above with the method you used.
1.Vlc may decode the stream first, then re-encode it, and then send it though the rtsp.
2. DeepStream is based on Gstreamer. The rtsp module in gstreamer may lose packets while transmitting the video data.
do you recommend other RTSP simulation tool to get same count of objects from RTSP as in files?
My goal to simulate RTSP and get same results as I get from files
Please help
Could you refer to Build rtsp server to build the rtpserver? Could you attach your probe function and where did you add the probe function?
I tested using video files , RTSP simulation using cvlc and ffmpeg
below screenshot clvc to simulate RTSP
below screenshot ffmpeg to simulate RTSP ( Gst-nvstreammux:)
below screenshot for video files
I tried also ffmpeg tool as you see and still count of objects in files higher than ffmpeg and cvlc
Can you elaborate on this results and do we need to do any settings to get same results for RTSP as in video files?
Let’s narrow down that first.
1.Could you try to use the tcp protocol as lower transport protocols of the rtsp?
2.Could You use a h264 stream with just 1 frame for comparison?
